My Firepod FP10 has continued to work well over the past 6 years. I'm wondering if now is a good time to consider upgrading to something newer. How do the preamps in the FP10 compare to newer offerings from Presonus as well as Focusrite (18i20) and even Behringer(ADA8200)?
My budget is around 500 and I absolutely need 8 inputs if not more - I record drums and full band live sets sometimes. I'm also not a pro engineer and am not ready to jump into pro tier hardware. |
Firepod/FP10's are ok but yes, other models have better pres. I have several Firestudio 26x26's and a Firestudio Mobile. Both feature Presonus' XMAX pres which are superior to those in the Firepod.
Another thing to consider is firewire itself. Many newer laptops have neither firewire or a PCI expess slot to let you add a firewire card. Personally, I would not switch to Focusrite. I've seen too many reports of problems. And if your DAW is Studio One I would stick with Presonus. Their hardware and software integrate seamlessly.
My system is a boxed PC, not mobile, so I have a Firewire card (TI) good to go there.
Other than firewire and Focusrite, what modern audio interfaces with 8 or more dual XLR/line inputs should I be looking at? Again kind of in a budget (500 or so) |
Well then, as long as you've got a card with a TI chipset, (the ONLY way to go IMHO, I've had problems with both Ricoh and Via chipsets), sticking with firewire is a totally viable option for you. I love my Firestudio 26x26's. They have better pre's and more routing options than the FP10.
I own three of them. They can be expanded by firewire daisy chaining OR ADAT. I've also got a MOTU 8PRE which I can add to the Firestudios for a total of 32 channels! Not that I've ever needed that many. I've also owned a Mackie 1640i which combines a 16 channel analog mixer with a 16 channel that worked flawlessly. it was a bit heavy to lug around but great in the studio. I only sold it as switched to mainly live recordings some years back.....of course, there's not much or that going on right now...LOL!! I've had some bad experiences with Tascam products. Poor quality control and horrendous customer support. I would also stay away from Steinberg hardware. They've always had a poor track record and now that they are part of Yamaha I trust them even less. Yamaha is notoriously bad when it comes to hardware support. M-Audio has also gone downhill, IMHO, since they were acquired by Avid. Of course, nothing beats RME but that's some pricey kit.
