FP10's won't stay synced.
Posted: Tue Mar 14, 2017 6:43 pm
by hemispheres_rush@yahoo.com
Have 2 FP10's running on Windows 7. Using with studio one. They lose, then immediately regain sync about every 10 minutes, or sometimes evry 3 or 4 minutes. Just upgraded computer to a SSD. Was working fine on old hard drive, however, did have same problem a couple years ago with same setup with original hard drive. Seemed to stop after deleting and reinstalling fp10 driver a few times. Thats not working this time. Help?
Re: FP10's won't stay synced.
Posted: Tue Mar 14, 2017 11:07 pm
by cristofechabot
Two questions. Do the FP10's sync to your pc individually with no problem? And when you do chain them are you making sure you have the one with the highest serial # first in the chain.
