Have 2 FP10's running on Windows 7. Using with studio one. They lose, then immediately regain sync about every 10 minutes, or sometimes evry 3 or 4 minutes. Just upgraded computer to a SSD. Was working fine on old hard drive, however, did have same problem a couple years ago with same setup with original hard drive. Seemed to stop after deleting and reinstalling fp10 driver a few times. Thats not working this time. Help?
Two questions. Do the FP10's sync to your pc individually with no problem? And when you do chain them are you making sure you have the one with the highest serial # first in the chain.
That being said we can help you better now and in the future with a bit more info......if you will post your system specs in your signature, (see my sig), we will be better able to troubleshoot your problems. Without knowing what type of pc you're running, what OS you're using, what DAW etc....we often can't recommend a "simple fix" |
