FS2626 - Updating from FS Control Panel Software and Firmware to Latest (Supported) Universal Control for WinXP SP3
Posted: Mon Sep 05, 2016 5:12 am
Hi All,
This is my first post - I'd pasted it into a thread on Win 10 but now realise this should have been in it's own thread - my apologies to admins/previous posters for any inconvenience caused...
I'd been searching the forums for Firestudio 2626 articles, and this one https://forums.presonus.com/viewtopic.php?f=160&t=18434 seemed to be the most relevant, I'm hoping the knowledgeable who've posted here re: Win 10 might also be able to shed some light on my set up/updating woes - this would be very gratefully received!
I'll try and keep it brief, whilst giving enough details - I've added some setup items to my signature to help clarify - my essential goal is to determine if I am able to update my Firestudio 2626 software (and Firmware) to Universal Control software, and how to do it;
A summary of the last few days' efforts could be as follows:
1. Recently rebuilt studio setup - Firestudio was last used circa 2014, running original Control Panel V 1.0 and Firmware Version 1.04 on Win XP Pro SP3 (32-bit). I've nothing attached to the 2626 atm, as I'm setting up slowly - it's been a few years between drinks so-to-speak, so I'm keen to understand and update each element in the set up phase to it's "current" state prior to launching into creativity; I expect to be running Cubase SX3, to sequence a range of recording projects - primarily guitar audio, and electronic instruments/samples;
2. I understand the product differentiation between each of the Firestudio models, that the 2626 is no longer supported, BUT that the 2626 is able to run/compatible with the later-released "Universal Control" software package, which was an update/replacement to the original "FS Control Panel" package originally bundled with the Firestudio; The latest available version of Universal Control compatible with WinXP Pro SP3 is V1.2 via legacy downloads page at Presonus' website;
3. I've downloaded this latest package several times, un-installed the FS Control Panel (FS CPL), however the installer either (a) gets to it's end though will not show/allow selections for the internal clock, OR the buffer size (both show as blanks), indicating to me that the install hasn't successfully worked; Or, (b) the software simply does not respond after the automated restart; In the 3b scenario, the Firewire sync light is showing BLUE indicating it's connected and sync'd, but with no launchable software window;
4. The original FS CPL software has no way of updating Firmware or Software manually, so I'm unable to get to the process from "inside" the 2626 when it is visible/connected to FS CPL; I've tried manually updating the driver AFTER an "unresponsive" install through WinXP Device Manager, which updates the drivers as listed, but does not allow the Universal Control Software Panel to open (it just hangs, with "Not Responding" status in WinXP Task Manager);
I'm open to any suggestions, as this is hindering start up of new studio projects. I'm loathe to simply buy a new unit, as there's nothing wrong with the XMAX Class A preamps and audio processing power in the current unit, and this would seem wasteful.
If anyone has an idea of what may be causing the issue, I'd be very happy to hear from you;
