Hi there
I'm planning of using the Presonus Firestudio for an installation running 24 channels of audio. I'm using 2 behringer ada 8000 to get the other 16 channels of adat audio, but I run into problems with the first adat 1 -8 outputs. I'm using Maxmsp to play back my outputs and sound files and I'm getting the first 8 channels and the last 8 channels. the middle channels seem to be unplayable. The levels are showing in Universal Control but no output or sound. i've check all the cables and all are working well. Anyone have an advice on why this is happening? and how I can solve this problem? hope to hear from someone soon. best |
Hrmn....that should work. The only thing that comes to mind is that the ADAT channel count is cut in half if you're working in 96k.
