Hello all,
I have been using my presonus firestudio for many years and recently it has adopted some strange buzzing noise. I'm using an iMac, going into QBase AI five. I've tried different outlets thinking that may be the issue with different power conditioners, and still no fix. Does anyone have any ideas?
by cristofe on Mon Jul 14, 2014 8:56 am
You said you've been using the FSP for many years.....but are you using it with the same computer you've been using it with? Or is the iMac new? And, if so, did the problems start after you switched to this machine? If you have not already done so please register your Firestudio and open a tech support ticket.
