Tube Preamp with Firestudio Project
Posted: Sat Apr 20, 2019 7:58 am
by Black_Haus
Hey guys,
I’m looking into getting a tube mic preamp. Most likely the ART Pro MPA II.
How would I go about connecting this to my Firestudio Project interface?
I’ve watched a few videos and read some articles on the subject but would like to hear from someone here that has used it with this interface.
Thanks in advance
Re: Tube Preamp with Firestudio Project
Posted: Mon Apr 22, 2019 10:07 am
by matthewgorman
Balanced out on the preamp to any channel 3-8 on the FSP. Use a 1/4" trs to trs. inputs 3-8 on the FSP will bypass the gain stage on the FSP when you use a 1/4" connection.
Posted: Mon Apr 22, 2019 6:12 pm
by Black_Haus
Matthew,
Thank you for the reply.
Can I also use the "returns" 1 & 2 on the back of the unit?
The manual states that "Their gain structure
is identical to the ¼” inputs for channels 3-8 and are typically used for signals not requiring
preamplification"
Just want to make sure I don't screw anything up.
Posted: Mon Apr 22, 2019 8:22 pm
by matthewgorman
Returns would work too. Just make sure you have the same routing options with them. I cant remember how they show up in a daw.
Posted: Fri May 24, 2019 1:33 am
by MarkusHassold
you can take the returns of channels 1+2 . Works as expected.
