Hey guys,
I’m looking into getting a tube mic preamp. Most likely the ART Pro MPA II.
How would I go about connecting this to my Firestudio Project interface?
I’ve watched a few videos and read some articles on the subject but would like to hear from someone here that has used it with this interface.
Thanks in advance
Dell XPS 8930 - Win10 64-Bit i7 8700K 32GB RAM 512 SSD 2TB HD S1 2 Pro, S1 3 Pro & S1 4 Pro
HP Omen - Win 10 64-Bit i7 7700HQ 12GB RAM 1TB HD S1 4 Pro
Firestudio Project x 2, StudioLive 16.4.2, Audiobox 44VSL Yamaha HS8 & HS10
Roli Seaboard Block & Lightpad, Nektar Impact LX49+, Fender, Gibson, Marshall, Mesa Boogie, Avatar, ADA, SWR
https://www.zeroempire.net
http://constantcollision.com
by matthewgorman on Mon Apr 22, 2019 10:07 am
Balanced out on the preamp to any channel 3-8 on the FSP. Use a 1/4" trs to trs. inputs 3-8 on the FSP will bypass the gain stage on the FSP when you use a 1/4" connection.
by Black_Haus on Mon Apr 22, 2019 6:12 pm
Matthew,
Thank you for the reply.
Can I also use the "returns" 1 & 2 on the back of the unit?
The manual states that "Their gain structure
is identical to the ¼” inputs for channels 3-8 and are typically used for signals not requiring
preamplification"
Just want to make sure I don't screw anything up.
by matthewgorman on Mon Apr 22, 2019 8:22 pm
Returns would work too. Just make sure you have the same routing options with them. I cant remember how they show up in a daw.
by MarkusHassold on Fri May 24, 2019 1:33 am
you can take the returns of channels 1+2 . Works as expected.
Presonus Firestudio Tube, Firestudio Project with Universal Control 1.7.6, Presonus Faderport, Bluetube DP, HP 4, Bluemax.....
Presonus Studio One Pro 4.5.x
Celemony Melodyne Studio 4.2
Softube Console1 MK II, Volume 2
- Mac Mini 6.2, (2014), internal SSD+HD, 2,3 GHz Core i7 quad, 16 GB RAM, MacOS 10.14.6 Mojave
- iMac 27" 3,4 GHz Core i5 quad, 1TB Fusion-Drive, 40 GB RAM, MacOS 10.15.1 Catalina
External harddiscs (3.5" - 7200 rpm) USB 3.0. - no interfaces on this one due to missing drivers.
