Problem with separate cue mixes on FireStudio Project outputs
Posted: Sun Aug 19, 2018 10:41 am
by AkronPark
Hi all,
I have two FireStudio Project units chained together. I have the outputs (3,5,7) on each patched to a headphone amplifier. On the master unit (fw to daw) I have the main output patched to my Monitor Station.
If I create a cue send for any of the secondary unit outputs (3,5,7) I get full separation/individual mixes as expected.
If I create a send for the master unit (3,5,7) then all of those outputs are getting the same output and there is no separation. Also, the same output is present on the secondary unit outputs as well.
How do I configure the units to have full separation on each of the outputs (master and secondary) so that I can have up to six separate cue mixes?
Thanks for any help you can provide!
-Dennis
