Goodmorning,
I own a fire studio project and notice the last few months (sometimes) the next problems.
1. When i've switch on the device there is no sound. I have to switch it off and on again and then it's working. No problems.
2. when I plug in a headphone. on some inputs the lights are starting to burn.
anyone with the same problems.
regards from Holland
Jan van Duren
Best regards
Jan van Duren
System
Apple Imac
3,4 GHz Intel Core i5
32 GB 1600 MHz DDR3
Os Sierra
Logic pro X
All drivers and software are updated
by cristofe on Sun Feb 05, 2017 1:26 pm
That's a little vague. First off, is the unit syncing properly? In other words, when you are experiencing these problems is the sync light on you Firestudio blue or red?
by schotland on Mon Feb 06, 2017 2:36 am
Goodmorning,
yes , i've read the manual :D I'm using the Firestudio for 5 years now.
The problem started a few months ago.
The syncing is normal.
Best regards
Jan van Duren
System
Apple Imac
32 GB 1600 MHz DDR3
Os Sierra
Logic pro X
