Goodmorning,
I own a fire studio project and notice the last few months (sometimes) the next problems. 1. When i've switch on the device there is no sound. I have to switch it off and on again and then it's working. No problems. 2. when I plug in a headphone. on some inputs the lights are starting to burn. anyone with the same problems. regards from Holland Jan van Duren |
That's a little vague. First off, is the unit syncing properly? In other words, when you are experiencing these problems is the sync light on you Firestudio blue or red?
That being said we can help you better now and in the future with a bit more info......if you will post your system specs in your signature, (see my sig), we will be better able to troubleshoot your problems. Without knowing what type of pc you're running, what OS you're using, what DAW etc....we often can't recommend a "simple fix" If you have not already done so please READ THE MANUAL!
