Hello,
Until this morning my Firestudio project operated properly (the light was blue). This afternoon, I switched on the device and I saw the light was red. I visited the site of presonus and I saw there was a new download available (Universal Control 1.7.4 (v5773)). I ran the download, restarted my pc (running Cubase 5 on Windows 7 64-bit) but the light of presonus remains red.
Has anyone experienced this problem? If you have any suggestions I would appreciate it.
by cristofe on Sun Oct 23, 2016 1:12 pm
It sounds like the problem maybe the Firestudio itself. If it's firewire port has gone bad it will not sync no matter what version of UC you use. There is also the possibility that the firewire chipset on your pc or the firewire cable has gone bad. Have you tried any other firewire devices or other cables? If you have not already done so I suggest you open a support ticket. If need be Presonus can repair your unit for a flat fee of $85.....this also get's you a full year warranty.
by kostassamourelis on Thu Oct 27, 2016 11:58 am
Hello Cristofe,
fortunately the problem solved. It was the firewire cable. I tried three different cables and the third one worked out.
Thank you very much for your immediate response and support!
Kostas
by cristofe on Thu Oct 27, 2016 12:25 pm
Hey that's GREAT!! Glad to hear you're up and running. Firewire can be very finicky and not all cables are created the same. Particularly if you're trying to go from firewire 800 to firewire 400.
Then it becomes imperative to use a bi-lingual cable.
