Greetings,
Studio One Pro V3 says that it cannot initial the FireStudio Project when I select it in the configure menu.
I am using a Dell laptop with a built-in FireWire port, with a clean install of Windows 10.
I am running the latest version of Studio One Pro V3 and Universal Controller. Sorry I didn't provide version numbers but I just downloaded them from Personus last night.
The light on the FSP when powered on turns red then blue for a moment and then back to red.
Studio One Pro and Universal Controller can see the FSP.
So everything appears to be working except Studio One can't initialize the FSP.
Any help would be greatly appreciated.
Rick...
Setup: FireStudio Project, StudioOne V3 Pro, Universal Control 4.1.3.17357, iMac 16GB RAM - OS X Yosemite 10.10.5
Polish comes from the cities; wisdom from the desert--Arrakeen villager saying.
by matthewgorman on Fri Aug 19, 2016 10:24 am
Its not syncing. When the FSP is synced to the pc, the light is solid blue. red means no sync.
Back in the Win 7 days (and maybe 8 but I wasn't on that train), there was a fix that may be worth a try. Go into the PC control panel/device manager. Find the IEE 1394 device (firewire port), rt click that for detail. Then on the drivers tab, it lists available drivers. If you see legacy as an option, switch to that and see if it helps sync.
Otherwise, it sounds like its possible that the firmware did not load correctly. Run the uninstaller for UC 1.8, then reinstall. On the reinstall, make sure that anti virus is off if applicable. Then also make sure that on the driver selection page, that the firestudio driver is selected for install.
After years of never having to deal with things like this, Win 10 has changed a few things for me too. I never had to turn off av, now I do. Things like that. Good times.
One other situation I have encountered, and it may help you. Doing a selective driver install, I have had device sync issues. If your first attempt at installing 1.8 was just installing the FSP driver, try to install all drivers for firestudio, audiobox, etc. For some reason that cleared it up on my system. No harm in doing this other than the odd Audiobox would not initialize message or similar. That just means that a driver was installed, and the device is not connected to the pc.
Matt
by Hagrid on Fri Aug 19, 2016 11:18 am
Thank you for the suggestions, I will try them tonight and report back.
Thanks again for helping.
Rick
by matthewgorman on Fri Aug 19, 2016 11:59 am
Not a problem. If none of those things work, I recommend a support ticket. I am leaving for vacation for 2 weeks, so I probably won't be responding at that time. Didn't want to leave you hanging.
Matt
by Hagrid on Fri Aug 19, 2016 8:11 pm
Here's an update.
I did try some of the suggestions above, but no luck.
After doing some more research, I found that Presonus provides a list of Firewire/1394 host controller chipsets that are not compatible with their products. As it turns out, the 1394 host controller chipset in my laptop is not compatible. The chipset built in to my Dell Studio XPS laptop is made by Ricoh, and Ricoh is listed as one of the worst. In fact, all the Ricoh chipsets are on the incompatible list. Lucky me!
Rick
by cristofe on Sat Aug 20, 2016 10:36 am
I don't know if your Dell has a pc express card slot, but my Dell Lattitude E6410 does. I use a TI based card as my machine had the crappy onboard Ricoh chipset too.
by huss724 on Mon Dec 12, 2016 8:17 pm
i got a hp 64 bit n i cant get fire studio to initalize smh
by Spyrofunk on Thu Apr 06, 2017 1:38 am
Just for the heads up.
DId you guys try the legacy 1394 drivers?
https://www.studio1productions.com/Arti ... wire-1.htm
OS: Win10 x64 - Machine: i7 3770k @ 4.6ghz (on water) - 32gb RAM - 3x 256GB SSD Geforce 660gtx - 3x display @1920x1080 - Presonus Firestudio Project - Monitor Station V2 - Presonus Dual Bluetube v2 - Faderport - TEC Breath controller - 4x Launchpad Pro - Ernie Ball VPJR volume pedal - Keystation 88MKII - KORG PadKontrol - KORG Nanocontrol 2 - 10x AudioCubes - Manhattan MondoHub 32 ports (4amp total) - Bunch of mics - AKG701 and AKG712pro (mixing) and Extreme Isolation (recording) headphones, 9 guitars 1 lapguitar- 2 basses, Zoom G5 Guitar pedal board, A3 and MS100BT Pedals.
