All the meter lights are on the first green level of each meter and there is a humming noise. Help!
Reason: Moved to FireStudio Project forum. |
Hard to tell without you posting your specs. Are you using balanced or unbalanced speaker connectors? If you are not sure look at your connectors. Balanced has a tip/ring/sleeve and unbalanced just has tip /ring. Are you recording guitar? Touching the pickups will amp up the noise if using tip/ring.
Skip
Have you changed anything recently? Almost sounds like a grounding issue. Is it across all your channels whether you have something plugged in or not?
I think it's time to send it in for repair. It could be a loose solder joint on the circuit board that could be grounding something out. 3 years seems like a short time, except for electronics. :/
Somewhere in the old forum there was an issue with a Elco in the powersupply .
You could search on that! Edit: Found it! http://forumsarchive.presonus.com/posts/list/19976.page |
