my name is Ludovic, I ask for your help because I have to solve a problem with my new set of Presonus Firestudio Project Interfaces. (2 pieces for 16 analog tracks recording) I precise I do work on a 27’’ Imac with I5 and 32GO ram, 3TO Fusion Drive. Everything went ok installing STUDIO ONE & UNIVERSAL CONTROL. (Even if I had to uninstall U.C. DVD version which was faulty in order to download an updated version which seems ok.) My problem is that I have no stereo signal. I mean, when a signal is centered, I have both speakers working, but when I try to pan it Left or Right, I just lose some level/power, but the signal remains centered. Anything I try to do in Studio One or UNIVERSAL CONTROL just changes nothing to that. I did spend a lot of time checking routings, trying different things, but it never worked, my signal dwells sticked to the center… Checking the U.C manual, it is written that signal from master outs L/R was also present in ouputs DAW1/2 by default. I precise I actually have no signal coming out from DAW1/2 outs. Browsing the web to find a solution, I then realized that many many people using UNIVERSAL CONTROL encountered the same problem, be it with STUDIO ONE, PROTOOLS, CAKEWALK, CUBASE, LOGIC AUDIO or other softs like REAPER… I came to the conclusion that the thing to fix was not into the audio soft, but rather into the UNIVERSAL CONTROL routing. Having a record to produce very soon, I ask for your help, especially as a dealer with customers to inform. Thanks for helping, Ludovic |
Hi again.
Just installed Studio One 3 to see if things would go on better. But this wasn't successful. Explored a little bit more and did some testings, tried to use the internal Imac sound card and stereo works fine that way. This makes me quite certain my stereo problem comes from the UNIVERSAL CONTROL settings or drivers... Maybe this piece of news helps... Regards. Ludovic |
How exactly are your outputs connected?
My outputs come out from Master L & R back of the Firestudio Project. Tried DAW 1/2 : no sound. In Studio One my outputs go thru 1/2 also. Did create in advance a new bus on DAW 3/4 for future headphones cue mix. But just created it, did not use it yet... When I move to the Imac onboard soundcard and play a mix in Studio One, stereo is ok...
Do you have outputs 1 and 2 panned hard left and right in VSL?
Sorry - brain fart. I read all forums and thought I was in the VSL forum. My bad.
When you are in the UC have you checked that the little blue dot on mixer 1/2 has light ?
Also your Daw 1 and Daw 2 should be linked, that you can do by making shure that the little link sign is lighted (11/12) also be shure that you have not by accident muted the daw's m into orange. Last thing, have you, in you daw, switched to the projects as soundcards ? Hope that it helps.
klypeman wroteWhen you are in the UC have you checked that the little blue dot on mixer 1/2 has light ? In UC, on the right, OUT 1/2 is on and it is written 1/2 MIXER, if I click the little blue dot, the text written changes for 1/2 DAW 1-2. In both cases sound comes out. Yes both tracks (17/18) are linked and panned full and I can see the signal going through on the virtual baregraphs... (clicking on the dot to link it pans it automatically) About muting, I can easily mute or de mute, it works fine, but it's not the problem... In the DAW, I can also chose with no problem between Onboard sound card or Firestudios. That's how I realized that stereo had no issue with internal sound cad but wouldn't work through the Firestudios... So much time spent on that issue, I'm just wasted... |
Yeaaaaaaaaaaaahhhhhhh !!!!!!!!!!
It works, I'm a [MOD EDIT] retarded ! After almost 1 week looking for the cause of my problem in the DAW and Control Center, my eyes saw a red light and stopped on it. I root my monitors through a Mackie Big Knob. And the MONO SWITCH WAS ENGAGED !!!!!!!!!!!!!!! So it's ok, I feel dumb... Many thanks for your help guys... Regards...
Reason: Edited for language. |
I am happy for you
