Hey there, everybody!
So, I just pick up another used FS Project. Plug it in, turn it on and the sync light blinks blue ONCE, then goes solid red. I have another FS Project, which is (and was) plugged in to same computer with the same firewire cable and it works fine (meaning it syncs and lights up blue). I started a ticket with Presonus and got an auto response that said the ticket is now closed because they don't support Vista anymore, so I don't expect much help from them. That was fine when they said that about my Faderport. I just threw away the Faderport and got a Mackie MCU. But I'd kinda like to fix this problem this time. From my reading on this, it sounds like it may need to get sent in to get fixed. Is there somewhere else that can fix this stuff besides Presonus? OR, better still, is there a different fix I haven't stumble across yet? Thanks, Sean |
Have you tried running Universal Control and updating the firmware in your FireStudio Project? This is what I would try first.
PreSonus has legacy versions available, so you should be able to find the last one with support for your OS. IIRC the firmware updates are part of the Universal Control software. |
Well.....if you have an FSP that works on this system and this one isn't recognized by the pc I would suspect that you've been sold a unit with a bad firewire port. Did you try to daisy chain them together? If it will not sync after daisy chaining it or updating the firmware I wouldn't contact tech support.....I'd contact the seller and demand a refund.
Can I do firmware when there is no blue light? When I click on the UC, it's empty (shows no device)
SO, when daisy chained to the functioning FSP, it does the same thing- solid red light/not recognized by the UC. When I bought it, the seller DID say it won't sync and the final auction price wound up around $25. I figured if it wasn't a firmware issue and was a capacitor or firewire connection, I could at least send it in for repair.. I didn't realize Presonus won't let me send it back if I'm running a no longer supported OS. I saw some videos online about testing/replacing the capacitors. Maybe I'll go that route |
Yeah...no sync...no firmware update...what was I thinking?...duh!!
When I bought it, the seller DID say it won't sync and the final auction price wound up around $25. I figured if it wasn't a firmware issue and was a capacitor or firewire connection, I could at least send it in for repair. Well that's it then.....almost certainly a fried firewire port. . I didn't realize Presonus won't let me send it back if I'm running a no longer supported OS. Oh no...that's not the case at all!! They no longer support that OS BUT they certainly still support the device and will repair it for a one time fee which I believe is currently $85. That also buys you a brand new shiny 1 year warranty!! So really, given what you paid for it initially, that still ends up being a really good deal!! Congrats!!
