Ok, so, i've been trying to figure this out for a while and I must be a total numbnut.
I use logic pro-x. When I record bass, i use a very distorted tone, like Type O Negative distorted. And i've been using the same patch for a while and I want to fiddle around with the tone. For my tone, I use the line 6 bass pod, the old school one that looks just like the guitar pod 2.0 only it's black.
What I want to do, is record the bass signal completely dry into logic, loop the playback and have the dry signal play back through my pod, so I can hands free fiddle with the pod until i land on a tone I'm happy with.
I cannot for the life of me figure this out. Im either an idiot because i'm missing something rather simple, or an idiot because it's not possible and I should know that already.
Any help would be appreciated.
by klypeman on Fri Nov 29, 2019 5:56 am
Mind I have not used Logic in years. But I think I have a workaround if you don't mind that the terms are not totally Logic correct.
What I would do in your case is to create a third Output in Output on the DAW, record the dry tone with the output set to Main Out and then make a Bus set to use the third Output and with the finished recording(dry) switch the output to the Bus instead of Main Out.
On the back of your Project you have 8 Outputs connect the one you picked as 3 Output with input on the Bass Pod and the Output on the Bass Pod to a new Input (set up in Inputs) and fiddle away with settings.
There are other solutions but this is Logic and as i said haven't used the DAW in years.
Cheers :mrgreen:
Windows 10 64bit Home, Studio One 3.5.6, Studio One 4.6.0, Cubase 10.5 Pro , Logic, Pro Tools, MacBook Pro, 24.4.2, 16.0.2, Project, Studiolive III 32, Midas 320, Yamaha MGP32X, Faderport 1+8, Mackie MCU, Softube Console 1, Yamaha SY 55, DSI Mopho, JU-06, ARP Odessey, Impulse 49, NI Maschine Mk.3, Atom, NI Komplete S61, Adam V7’s, KRK VXT 8´s, SE Electronics HP6, CME 61, Nocturn 25, UAD Plugins, TC Touch, UAD Apollo Twin USB/TB Duo, Satellite Quad, TB Octa, UA 6176, Warm Audio 76, JoeMeek MC2, DBX 266XS, TC C300, TC 2290, Yamaha REV 7. Toontrack. :mrgreen:
