Haven't had any issues until recently.
Tried recording and I noticed a ton of crackles and pops. Happens when I monitor too. I use my firestudio as my soundcard to and it plays music back just fine. It's only when it monitors and it gets worse as the input gets closer to clipping.
Windows 10, 16gb of ram. Tried different daws. Reinstalled drivers (uninstalled, restart, clean install). Same thing happens.
I think there was a recent update my PC went through which caused this? not sure.
I even went into my bios and disabled all my overclocking and set it to default.
Not sure what to try next. I don't think it is hardware or driver related more windows 10 related. Really annoyed. Ugh....
i7-7700k, Asus Z270-A, Windows 10 Pro, TI Chipset firewire controller, Firestudio Project w/ 6pin > 6pin cable ( Retired ), RME Babyface Pro, Studio One 3.5+, Softube Console 1, Faderport
by jefffillion on Wed Mar 22, 2017 8:30 am
I had that same problem exactly last week me too and dont understand the problem.
Did you solve it because I try some few things without success .
Im on Mac OS sierra , Firestudio Project with the last driver from Universal Control
by matthewgorman on Wed Mar 22, 2017 2:56 pm
jefffillion wroteI had that same problem exactly last week me too and dont understand the problem.
I would start a new thread for your issue since you are on a different OS than the OP.
by axxessdenied on Wed Apr 19, 2017 7:59 am
Haven't had any luck fixing it.
I've tried everything I can including swapping cables.
My last resort will be buying a separate firewire board and seeing if my motherboard is the issue. If that doesn't solve it than this unit is basically useless now as I can't get a clean recorded signal at all.
It plays back audio just fine and I can still use it as a soundcard. Just not for recording which is a huge bummer. I actually had to go out and buy another interface JUST so I can record something.... ugh.
by matthewgorman on Wed Apr 19, 2017 9:05 am
axxessdenied wroteHaven't had any luck fixing it.
I recommend opening a support ticket before you spend any more money. TS is better equipped to troubleshoot issues like this.
by matthewgorman on Wed Apr 19, 2017 10:20 am
Seems there have been issues cropping up with native FW drivers in win 10. We had seen this before with Win 7 in the early days.
One thing you can try. Go into Win control panel device manager. Rt click on the FW device (1394 is how its listed I think). Go to the drivers tab, and select "Legacy" as the FW driver. Reboot, and retry everything. Hopefully that fixes your issue.
by klypeman on Thu Apr 20, 2017 5:32 am
Have you replaced the fuse ? I had a similar problem way past and turned the fuse beside the power cord the other way around, that solved my problem without needing to buy a new fuse. :)
Another time I had to cut around 1 mm plastic off the Firewire cable to go into a 1394 Inspire to go a little futher in with the cable. I don't say that is needed but is an option to consider.
Windows 10 64bit Home, Studio One 3.5.5 Pro, Cubase 9.5.10 Pro, Logic, Pro Tools, MacBook Pro, 24.4.2, 2 Projects, Firestudio 2626, Firestudio Mobile, Faderport 8, Mackie MCU, Softube Console 1, All Steinberg CMC´s, Yamaha SY 55, DSI Mopho, Roland JU-06, Novation Impulse 49, KRK Rokits 6´s, KRK VXT 8´s, SE Electronics HP6, SM Audio Mpatch 2.0+ 2.1, CME 61, Nocturn 25, UAD Plugins Galore, TC Voicelive Touch, Faderport, UAD Apollo Twin Duo, Satellite Quad, Quad PcIe, Warm Audio 76, JoeMeek MC2, DBX 266XS. TC C300x3, Yamaha REV 7. Toontrack Galore.
by axxessdenied on Sat Apr 22, 2017 9:41 pm
I decided to upgrade my pc. We'll see how it goes. I got a brand new power supply as well just in case.
