Every once and a while, the microphone audio will switch to distorted robot sound, and I have to reset the bitrate to make to come back to normal.
Here's an example .
https://clyp.it/vafpqeuw
Also the headphone out likes to skip and pop
by cristofe on Wed Jun 28, 2017 12:30 pm
Sounds like maybe your buffer settings are too low.....that would also explain the headphone "skip & pop". But, It could be any number of things. Have you optimized your pc for audio production?
Have you disabled wi-fi? Did you install the drivers from the included disc? Or did you download and use the latest drivers from this site? Also not all firewire chipsets are created equal. Are you using a laptop with onboard firewire? If so is it a Presonus approved chipset? Not all firewire chipsets are compatible with ANY firewire audio interfaces. Check it against this list:
http://support.presonus.com/hc/en-us/article_attachments/203654653/Approved_FireWire_Cards.pdf
