I'm looking in to picking up a second hand Firestudio Mobile (or FIrestudio Project). I read in an old reveiw from Sound on Sound that the latency goes to 256 samples. I would like to know if that's really the lowest value obtainable or can it go to 64 or even 32?
My macbook Pro is pretty well built and I can get to 64 with my aggregate of Toneport UX2 and Akai eie right now. I'm not going to assume things and be disappointed.
thanks in advance,
Luke
http://http://www.lukenyman.com
Sphere
Macbook Pro 15"
Faderport 8
ADAM A7 monitors
Akai MPKmini
Arturia Beatstep
Korg SV-1
Korg PadKontrol
Behringer X18 audio Interface (oh the shame)
by matthewgorman on Tue May 23, 2017 7:27 am
I have run it for audio at 64 with no issue.
S1Pro V5
by lukenyman on Tue May 23, 2017 8:54 am
Thanks for the verification, Matthew.
:thumbup:
Sphere
Macbook Pro 15"
Faderport 8
ADAM A7 monitors
Akai MPKmini
Arturia Beatstep
Korg SV-1
Korg PadKontrol
by matthewgorman on Tue May 23, 2017 9:11 am
Just to clarify, I work primarily with analog audio, and that setting was using the laptop in my sig. It has a 2.60ghz i5 processor.
S1Pro V5
by WaterlooSunset on Sat Jun 03, 2017 1:10 pm
I am late to the party. I run 32 or 64 @44.1 mostly. I just started to play with 64 which is the lowest it can do at 192. Its a good little interlace but has been out a while so at some point i would think it will go EOL. Just pure speculation...
I am curious if you get a blue Z as mine has been missing for ages. I am not actually missing it, it just used to be there. I monitor out my Behringer monitor2usb speaker headphone splitter thingie anyhow.
Win 10 latest, MSI G41 Z87, I4770K (no OC), 16GB, NVIDIA 710, 2x27" Monitors 1Tb SSD, 500G SSD, 3 platter drives. SYBA Firewire SD-PEX30009, FS Mobile. Monitor2USB, S1 Pro 5 current.
Hobbiest - Mainly Guitars, UVI, Soundtoys, NI, IK, EZ2, SD3, GR5, TH3, Amplitube 4 and 5, Waves GR,
Korg 707, NanoPAD2, MicroKey2. Eris 5, B2031A, 2013 R1200GS-LC.
by ctreitzell on Fri Feb 16, 2018 6:31 pm
These claims of sub 256 samples are surprising.
In which software? All the softwares in your sigs?
Personally, with Reason 4-10 the lowest I can comfortably work without clicks, pops or aliasing sounds is 512. I am talking about tracking and mixing, not playing live. I can get away with 256 with occasional clicks and pops, but 512 is solid. I typically work at 4824.
Same for SawStudio.
Even on my new 8700K Win 10 Pro machine, 512 works well. Some VSTs are optimized to deliver best results at 1024 or 2048, ie Sonnox Restore. Lower sample rates render aliasing IME.
SawStudio on Win 10 is currently a no go, tho :-| Win 7 is better for SAW.
i7 8700K ASRock Z370 Fatal1ty Gaming Pro 64GB Corsair Vengeance LED DDR4-3000 Palit GeForce 1050ti KalmX StarTech PEX1394B3 with 2x FireStudio Mobile daisy chain over 1394A Win10 Pro (1709) on Samsung960 Pro Propellerhead Reason 10 & 8.3 SawStudio Lite 5.6 Drawmer MC2.1 Adam A7X Avantone MixCubes
by cristofechabot on Thu Mar 08, 2018 1:14 pm
Claims that HIGH are surprising to me. I have no problem running at 64.
If you've set your machine up properly and it has enough CPU and RAM
you should be able to do the same regardless of what software you're running.
Sound like your machine is either underpowered or not properly set up for
audio production.
by mBrane on Thu Jul 05, 2018 8:28 am
WaterlooSunset wroteI am late to the party. I run 32 or 64 @44.1 mostly. I just started to play with 64 which is the lowest it can do at 192. Its a good little interlace but has been out a while so at some point i would think it will go EOL. Just pure speculation...
192 with a FireStudio Mobile is impressive! Pls share how you mod’d yours.
- mBrane
by WaterlooSunset on Thu Jul 05, 2018 10:19 am
I did not mod mine. I am at either set at 32 or 64 in UC running at 44.1 or 48.0 in S1
by mBrane on Thu Jul 05, 2018 5:35 pm
WaterlooSunset wroteI did not mod mine. I am at either set at 32 or 64 in UC running at 44.1 or 48.0 in S1
I'm just sayin', because mine only does 96 kHz. Unsure how you hit 192 kHz sampling rate, as you mentioned.
- mBrane
