I'm looking in to picking up a second hand Firestudio Mobile (or FIrestudio Project). I read in an old reveiw from Sound on Sound that the latency goes to 256 samples. I would like to know if that's really the lowest value obtainable or can it go to 64 or even 32? My macbook Pro is pretty well built and I can get to 64 with my aggregate of Toneport UX2 and Akai eie right now. I'm not going to assume things and be disappointed. thanks in advance, Luke |
Thanks for the verification, Matthew.
I am late to the party. I run 32 or 64 @44.1 mostly. I just started to play with 64 which is the lowest it can do at 192. Its a good little interlace but has been out a while so at some point i would think it will go EOL. Just pure speculation...
I am curious if you get a blue Z as mine has been missing for ages. I am not actually missing it, it just used to be there. I monitor out my Behringer monitor2usb speaker headphone splitter thingie anyhow.
Win 10 latest, MSI G41 Z87, I4770K (no OC), 16GB, NVIDIA 710, 2x27" Monitors 1Tb SSD, 500G SSD, 3 platter drives. SYBA Firewire SD-PEX30009, FS Mobile. Monitor2USB, S1 Pro 5 current.
Hobbiest - Mainly Guitars, UVI, Soundtoys, NI, IK, EZ2, SD3, GR5, TH3, Amplitube 4 and 5, Waves GR, Korg 707, NanoPAD2, MicroKey2. Eris 5, B2031A, 2013 R1200GS-LC. |
These claims of sub 256 samples are surprising.
In which software? All the softwares in your sigs? Personally, with Reason 4-10 the lowest I can comfortably work without clicks, pops or aliasing sounds is 512. I am talking about tracking and mixing, not playing live. I can get away with 256 with occasional clicks and pops, but 512 is solid. I typically work at 4824. Same for SawStudio. Even on my new 8700K Win 10 Pro machine, 512 works well. Some VSTs are optimized to deliver best results at 1024 or 2048, ie Sonnox Restore. Lower sample rates render aliasing IME. SawStudio on Win 10 is currently a no go, tho Win 7 is better for SAW. |
These claims of sub 256 samples are surprising. Claims that HIGH are surprising to me. I have no problem running at 64. If you've set your machine up properly and it has enough CPU and RAM you should be able to do the same regardless of what software you're running. Sound like your machine is either underpowered or not properly set up for audio production. |
WaterlooSunset wroteI am late to the party. I run 32 or 64 @44.1 mostly. I just started to play with 64 which is the lowest it can do at 192. Its a good little interlace but has been out a while so at some point i would think it will go EOL. Just pure speculation... 192 with a FireStudio Mobile is impressive! Pls share how you mod’d yours. |
I did not mod mine. I am at either set at 32 or 64 in UC running at 44.1 or 48.0 in S1
