I just want to know if I can use a daisy-chained 2 Presonus Firestudio Mobile as a soundcard for Xone 92 mixer, I've asked somewhere that I can only use 1 channel on the mixer with the firestudio mobile output can anyone confirm this? because I saw someone using a 2 Audioboxes to the Xone 92 see picture below
If this is possible then I think I can also use a daisy-chained firestudio mobile to 4 channels of Xone 92, correct? Thank you |
You're asking whether or not you can used daisy chained firewire devices with a Xone 92.
Unless someone here has that exact setup I think you'll likely get more/better answers on the Allen & Heath forums.
