I dint have problem before , but in last 2 months my FS Mobile connects and disconnects every 1 or 2 hours ..... is really annoying .
I Use iMac ( mid 2011 ) I try to connect the SC firewire to firewire and firewire to thunderbolt ... ( same problem ) Help Someone Vlada |
I try to connect the SC firewire to firewire and firewire to thunderbolt ... ( same problem ) Not sure what SC means. Can you provide more details on how everything is connected? |
Drivers are dependant on your operating system, which at this point I don't know what that is. Also, the type of firewire connection is important. Are you connecting firewire 400 (what the FSM has) to firewire 800 on the mac? If yes, you need to be certain that the cable used is rated as bilingual (same goes when using the tb adapter). If the cable is not bilingual, this could be the result.
Most of the reviews I saw of that cable (the flat cable design) point to the cable being your problem. It seems to be very sensitive and drops connection.
Make sure that you purchase a bilingual cable. If it doesn't specifically state bilingual in the product description, find one that does. |
The light will be red if not connected to pc, and solid blue if connected and synced. Any blinking of the lights, or alternating red means the unit is not synced.
