About 3-4 weeks ago I installed my newly purchased FSM and installed the Universal Control (UC)software and all was working fine until this past Sunday. After returning home from a recording session and plugging everything back in and then turning the computer on the FSM continuously blinks blue and red. When I log into windows 10 and the drivers have loaded I receive the error message: "The software was not installed correctly. Driver Error. Please reboot your computer and/or re-install and try again. Universal Control comes up and is completely non-configurable.
Several reboots and re-installations have been attempted to no avail. The FSM shows in the devmgmt.msc just fine without any internal errors.
I have even attempted to use the beta UC 1.7.4 as of today and still not working correctly.
Any ideas?
Thanks.
Stephen Morton MSSE
Computer system is a:
Toshiba X505-Q896
I7 .73mhz 1st Gen with 16GB of Ram
GPU: GeForce GTX 460M
Win10 Fresh Build 2016/05/20
by semorton1954 on Sat May 14, 2016 7:59 pm
This week I performed a complete rebuild of my system from scratch using win10. The first driver installed post system drivers was the Universal Control driver and the same error message continues to display and the light on the FSM continues to blink blue and red. Also the devmgmt.msc continues to show the drivers as being active and normal.
Any ideas or help would be appreciated. Thanks.
Stephen Morton MSSE
Toshiba X505-Q896
by cristofe on Tue May 17, 2016 9:48 am
You may find some answers in this thread:
https://forums.presonus.com/viewtopic.php?f=160&t=18434
by semorton1954 on Thu May 19, 2016 11:53 am
I ran your recommended procedure in the thread and it was of no help.
Thanks. Any other ideas?
Stephen Morton MSSE
Toshiba X505-Q896
by semorton1954 on Sun May 29, 2016 7:11 pm
After several reinstallations and a complete system rebuild I continue to receive the following two messages:
"User settins corrupt. Resetting.
If you see this message again, try to completely reinstall the application."
and
The Universal Control app pops up and indications:
1. Driver version: 0.0.0.0
. 5773
2. Sample Rate: 44.1 kHz
3. Clock Source: "Blank"
4. Safe Mode: "Normal"
5. Buffer Size: "Blank" and unable to change.
Toshiba X505-Q896
Does anyone have any ideas?
Thanks for your thoughts.
Stephen Morton MSSE
Toshiba X505-Q896
by Pfau_thomas on Thu Jun 02, 2016 4:10 pm
Sorry i come from German .
But i have the same problem .
The new driver for the Firestudio Mobile 1.7.4 have a bug.
That is not compatible with Windows 10 Pro 64 bit (version 14352.rs1) .
. 5773
My Computer :
I have one AMD Phenon 1066T Cpu 6 Core
16 GB ram my mainboard is from Gigabyte .
The System ist Windwows 10 Pro 64Bit (version 14352.rs1).
GPU: Nvidia GeForce 9400 GT.
by semorton1954 on Tue Jun 14, 2016 3:51 pm
Thanks. I'll wait for the next fix. In the meantime I have a device that is useless. bummer.
Stephen Morton MSSE
Toshiba X505-Q896
by WaterlooSunset on Mon Aug 29, 2016 11:39 pm
For what its worth and fitting to this thread (I am on Win8.1 though). I upgraded to S1 3.3.0. Decided to downgrade. That was yesterday. Today i noticed that my Firestudio Mobile is now showing up as a Firestudio inside 3.2.3. The picture changed as well. I dont have phones out anymore. I uninstalled, reininstalled, uninstalled rebooted in between many times, deleted from device manager, deleted the universal control directory, reininstalled, get the picture.
In the end i got the flashing red/blue light. Could not resurrect it. Now keep in mind, i have had the FSM since 2010, on my second one. I am familar with these puppies/ Only a couple of times, could i not fix this stupid thing real fast. Kept poking around. Found an .inf file (forgot the name) in the program files/universal control directory. Well, inf files you can right click on and get a choice of installing from the context menu. I right clicked, then clicked install and bada bing, light went immediately blue, no reboot. All is good in FS land.
I came here to post on how to get the proper Firestudio Mobile to show up and not the Firestudio inside S1. Must be a fragment, i didn't back up, when i put 3.3 on the dropped back to 3.2.3. Phone out gone. Get Daw1 - 6 out choices. Under Universal Control and in Dev Manager, i see it as the FS Mobile. Only inside S1 it shows wrong. Its late..........
Win 8.1, MSI G41 Z87, I4770K (no OC), 16GB, El Cheapo NVIDIA 710, 2x27" Monitors 480Gb SSD, 2x1TB WD Blacks. SYBA Firewire card SD-PEX30009, FS Mobile. S1 Pro 3.5.6 and 4.new.
Hobbiest - Mostly record guitars, UVI, Soundtoys, NI, IK, EZ2, SD3, BFD Eco backing inst. GR5, TH3, Amplitube 4, Waves GR,
by Anselmi71 on Sat Sep 16, 2017 12:24 pm
I have Windows 10 Pro 64-bit and last drivers which works for me is 1.7.2. I have Firestudio Mobile and TI chip FW card.
