Hello, I am wondering if anyone can offer some help.
I am running the Studio One 3 pro demo.
1. When using pipeline and when I try to ping, the meters show audio on in and out but when I ping, the display only shows the red (out) waveform. The blue is flatlined.
I am able to send audio through my hardware and the loop is definitely working. The hardware (compressor) is in true bypass mode so that is not interacting.
I am using an Avid Omni and HD I/O for interfaces on a macPro tower on Yosemeti.
by macsearcher1 on Sat May 30, 2015 4:29 pm
adendum.
On the Omni, The in's and out's don't match up.
It shows as having 8 in and 10 out so when you create an in and out on pipeline, you have to assign false numbers.
A bit confusing.
by franckmariani on Thu Jul 14, 2016 7:50 pm
I have the exact same problem as you with my orpheus, it's very anoying.
Don't know what to do.
Any idea?
Core i9 9900k - 32gb ram - windows 10 pro - studio one 4 - prism orpheus
by kristinnielsen on Sat Jan 27, 2018 3:37 am
I have the same issue, but only when using Pipeline with one of my hardware units.
other processors work with Pipeline when routed through the same soundcard using different channels.
if I play some audio then hit the ping I can hear the returned audio, and I can see the returning waveform.
however if I just ping with no audio playing there is no returned waveform to set the latency by.
any suggestions appreciated.
