I have a problem with my Presonus Studio One 2 free. I don't have any MIDI keyboards so I use QWERTY instead of MIDI keyboard. But the problem is that Studio One is getting a signal from my QWERTY, but there is no sound. I have already closed all the others programs that could interrupt the signal but even though there is no sound.
If someone could help me, I would be very thankful. |
Moving this to the S1 Free area.
You need to have an instrument selected on the track, with a sound selected, and make sure the monitor button is selected on that track. |
Ok. Go to the S1 start page. At the top, select StudioOne menu. Then look for installation and select. Then check the box for download from user account. That should bring up all the content that comes with Free. See if there are any soundsets in there, and download them. Then check to see if you have presets.
Off you go then Enjoy. Use the presets as a starting point, and then you can dial in your sound from there. If you stumble onto something nice, save that as a preset.
I've looked at all the videos and read all the information, but my midi keyboard does not make any sound when connected directly to the computer by usb cable. It does work when the blue tooth connection is made, but the latency problem makes for a significant delay on the audio signal.
Why does audio come through with the bluetooth connection , but not with the direct usb connection? The midi monitor shows there is signal, but I get no sound when connecting instruments, again only with usb cable The sound is fine, although delayed with bluetooth connection routed through midi studio. |
