I'm pretty new to S1 and recording in general, but I finally reached a point where I really want to focus on building recordings. I started with the Free, got all my hardware and interfaces up and going, got the mic placement just right, then recorded some simple stuff to test in S1. Played it back, it sounded great. I exported the mixdown to WAV ((free, so no choice for now)), and the recording comes out with a whole different sound, very roomy and airy is the only way I can think to describe it. So I decided to rerecord what I played using Audacity and the same hardware configuration, and it played back pretty much exactly the same as the exported WAV file. So my question is this... Does S1 playback with some sort of pre-applied EQ? Am I not exporting the song correctly to maintain the sound I got from playing it back in S1? Am I mentally challenged and simply missed something obvious?
by scottyo7 on Sat Jan 17, 2015 4:36 am
There could be a few reasons for this...
1) You opened a template with FX on some of the tracks.
2) You have automation unknowingly on the tracks.
3) You have an outdated driver on your AI.
But reasons 1-3 should also be heard while you're recording and balancing your tracks.
For us to better help you, please create a signature*.
ASUS G75VX, i7 3820QM; 16GB; 2 Samsung 840 SSD's; NVIDIA GTX 670MX. Win 8.1. PreSonus FP10; Thunderbolt-FireWire 800 iface (TI Chipset). USB 3.0 ports.
S1 Pro v3.5.4; EZDrummer 2.1.4; Synths: Alchemy, Air Music Technology Suite; Melodyne Studio 4.01.0111; & Ozone 5 (all 64bit).
Akai MPK249. Electric & Acoustic guitars. POD HD500 & an E-bow. Rode NT1; Shure SM58. Faderport; KRK Rokit 8's; Dual 28" ViewSonic monitors.
My Band: https://soundcloud.com/2guyzinabasement/tracks
Just Me: https://soundcloud.com/user-830723604
by jonmoler on Sat Jan 17, 2015 5:50 pm
Well, for the time being I'll put down what I can remember of the laptop until I can get back to the studio to check out some of the secondary stuff.
Asus MoBo, i7 2760, 16gb RAM, WD SSD, Two Focusrite 2i2 ((linked through ASIO4all)), Studio One Free ((looking into artist, but I want that MP3 functionality)), Ibanez & Schecter guitars, Line 6 Amps, Gretsch Kit, SM57, Beta 52, Two MXL 840s.
Step for step, I opened up Studio one, set ASIO4all as my default driver, linked together the two Focusrite Interfaces ((setting the headphones on the laptop as my output)), then opened up a New Song. Set a new track for audio and set for L+R input. After a bit of mic re positioning, I got this really awesome and tight sound through the S1 playback. The bass drum had some real feel and thud to is and while the cymbals didn't come out PERFECTLY, I'll chalk that up to my crappy overheads. Anything else info-wise I can provide?
Really, I'm happy with how it sounds as it plays back. I want to export it like that.
by jonmoler on Thu Jan 29, 2015 9:07 am
So, I take it no one has an answer or a clue regarding this issue?
by matthewgorman on Thu Jan 29, 2015 9:45 am
Try to do a mixdown of the song, with the setting to reimport the mix back into a track in the song. Solo that and playback. It should sound the same. If it does, then there may be something going on with the system you are listening back on.
A lot of times if you are listening through an onboad media program on your PC, there are eq settings that can be turned on that would affect the sound. If you listen to the mix on the same gear that you monitor S1 on, down to reimporting it back into S1, then the problem is most likely external.
The other possibility is the system itself and the room. If you take the mix out of your studio environment, and it sounds off there, Then your room/speakers/etc may not be telling the truth.
by mdouse on Wed Jan 04, 2017 8:06 am
I have the same problem, no qulity when mixdown. I play the songs on many different device same results. It is like there been pushed back in the same way that room effects whould effect the track but qulity is small,narrow and low on valume, please if anyone knows what is going on please help. So far i try everything that post here and i even try to load a song into my studio one without adding any effects mix it down and same thing it actually lost qulity when load and more when mixdown.
by kuba12 on Tue Jan 10, 2017 6:50 pm
I also have problems with exporting a mix down. For example: I’ve got a couple of tracks recorded , incl. instruments and vocals. I got some effects from the program used in them, I got stereo panoramas set in each track separately etc. And it all sounds great when I play it back in the program. But after I export the mixdown, all the pans settings for example disappear, and everything is heard in the middle. Totally not the way it sounds in the playback. It doesn’t matter what is the output file, WAV or any other, always doesn’t sound like in the playback before. Does anyone know why it is like that?
by jameschi on Mon Jul 17, 2017 8:06 pm
It happened to me when I had limiter on.
I'm not exactly sure why it fixed it, but when I took out limiter fx, the mixdown came out how it sounded on the software.
by tsgrizzi on Wed Mar 14, 2018 12:38 pm
Hi. I know this is an old thread, but I wanted to respond. I was having the same issue as discussed here using Studio One 2 (Artist version 2.6). I went to Song > Song Setup > Options > Audio tab. I deselected Use dithering for audio services and audio file export. The results have been night and day. My mixdown wavs finally sound like what I was mixing inside of Studio One. Of course, this may not be the same solution for everyone, but I wanted to pass along.
