I've set up my Midiplus X3 controller as a new external device with the settings as seen below. Despite S1 receiving the MIDI (also pictured below) it will not play the Presence synth nor do the controller transport buttons work. There's probably something simple I'm missing here but I just can't get it to work
This forum supports users. It is not meant for Presonus Technical Support!
If you have a technical issue with a Presonus product, please open a Support ticket. Did you watch any of the videos related to your question? Here's one to start with: https://www.youtube.com/watch?v=JrecZw04QWU Make sure after you properly setup your external instrument that you select that as the input device for the track you have your plugin synth connected to. Looks like you have the input coming into Studio One but don't have the output assigned yet. |
Have you set up your device twice, as a keyboard and a controller?
Ok so when I have Studio One edit mode selected and click on the instrument track it will play the instrument for that track. Cool. But... if I open the instruments interface and click on the tabs at the top (Presence 1, Presence 2 etc) it won't play the selected instrument, it will still only play the instrument that's selected on the track in edit mode. How do I get it to play the focused instrument from the tabs in the instrument interface?
Studio One doesn't route midi automatically to instruments that are in focus. The midi routing must be defined first using the instrument track routing or each instrument's direct midi input. If you want to play only one specific instrument without setting up a specific routing, you can use the "Instrument Input follows selection" option. But then the element that should be in focus is the track, not the instrument.
