Hi, Just downloaded the trial, when I try to browse to an MP3 it is not visible and I can not drag it onto an audio track. I'm using the demo which should allow this ? MP3 spec below.
Thanks Format : MPEG Audio File size : 3.33 MiB Duration : 3mn 38s Overall bit rate mode : Constant Overall bit rate : 128 Kbps Audio Format : MPEG Audio Format version : Version 1 Format profile : Layer 3 Mode : Joint stereo Mode extension : MS Stereo Duration : 3mn 38s Bit rate mode : Constant Bit rate : 128 Kbps Channel count : 2 channels Sampling rate : 44.1 KHz Compression mode : Lossy Stream size : 3.33 MiB (100%) |
viewtopic.php?f=151&t=1037
Does not look like it works in demos. Good time to get a supported version while they are on sale.
The demo IS full featured. MP3 support is an ADDON:
MP3 Converter is an extension that adds professional-quality (up to 320 kB/s) MP3 encoding and drag-and-drop MP3 decoding to Studio One Artist 2.6.2 and higher. U.S. pricing: MP3 Converter $9.99.
mp3 is the only functionality that does not work in the Pro demo. There is a licensing fee for mp3 encoders, which is probably why it is not included in a free trial.
Matt
Lenovo ThinkServer TS140 Win 10 64bit, 8GB RAM, Intel Xeon Lenovo Thinkpad E520, Windows 7 64bit, 8 GB RAM, Intel i5 Processor StarTech EC13942 34mm Expresscard S1Pro V2 , Melodyne Studio 4, Nomad Factory Studio Bundle, Waves , RM16, Studio 192, DP88, Faderport, Central Station Plus, Yamaha HS50 Monitors, Sceptre 6-8 Monitors, Temblor 10. |
If you have to use an MP3 just re capture it, or if you can convert the MP3 to a wave file, waves drop right in. Our singer is on Artist and he has just re-captured any MP3's if he had to import it into a track. He is using an iTwo Audiobox, plugged his phone into the iTwo input hit play/record and captured. We use that as a temp work around for scratching ideas and fast sharing.
But with the sale going on NOW is a perfect time to upgrade. I just downloaded Pro yesterday ![]() |
