Project Tempo - Playback Bug???
Posted: Wed Sep 19, 2018 5:51 am
I primarily use studio one v4 for music transcribing. Below is my common workflow.
- Load audio file to Studio One
- Tempo map it so the project click is aligned properly with audio file
- Add LH and RH tracks for piano. Allows me to mute LH or RH and work on them separately
- Create loops and change tempo to desired speed
- Transcribe what I hear into MIDI track
All this works nice and does what I expect it to except for one thing, which I think could be a bug or a feature of the program that I would like changed. Let say I am inside a loop I created and its looping one bar of the song. All good, I put down some notes, at a slower tempo then I like to increase the tempo to normal and make sure it sounds good. When once I change the tempo of the project, the playback place goes somewhere else and I am not back on min 1 of the song even though my look is on minute 4. No major, I move it by hand to near or inside the loop and play the loop a few times again. Extend the loop to keep working on it, then change tempo and back to minute 1. Is as if I had a marker on that section and always went to the same section when I change the tempo. I do not have any markers on that section that I can visually see. I have restarted the program and laptop a few times with no solution.
Has anyone experienced this? Anyone has any solutions?
