this happen only in instrument tracks. in audio tracks it stay on. this happen with all midi VST. i use rapid composer which send several channels for bass, chord, drums. so i set the input of 3 tracks with a instrument to rapidcomposer and diffrent channels select. monitor need always switch on for this tracks. but when i click in mixer or console or timeline on another track in the current active track is monitor switch off.
another thing i see happen witch VST that have a builtin sequencer. for example addictive drums and other drums have that. i use only stereo out. when press mute on the addictive drum track, do not mute the builtin sequencer play. only in mixer mute work. I look in prefs and see no settings to change that. |
True. It. can't do both things at the same time or know all by itself which of those two things you may want it to be doing at any given time. Most options that switch things on and off are like that.
Maybe make an FR to make it an action so that you can bind it to a hot key to make it easier to turn it on and off. As it stands currently, it just is what it is. |
