I have in my windows preference set scale 125%. but without use high dpi in pro one Options, fonts are very small and the midi editor images and notes are sharp. but the fonts are too small. So i use high dpi mode. text have good size and is sharp, but the midi editor notes look blur. the blur midi editor give me too pain in eyes as the in normal mode the very small fonts
Can the blurness change in any way ? BTW: studio one is best midi DAW i hear to play Lead guitar on board with Phat paul and the redlight dist+ ampire. when draw pitch bend using the parabel mode it sound like real guitar play. see attach the small example song. 1. with parabel pitch bend. 2. with no pitchbend. other track use linear bend, but sound not so good.
I have done a screenshot from my 1920*1080 display resolution now. forum allow only 800 pixel, so i make around 800*600 crop from the 1920*1080 image. here can see the lines in the arranger display are blur. should i upload the part of midi editor too ?. The text in the midi note names and lines in midi editor are blur too. the display in arranger is free scalable, but all scales are blur
problem happen when i set 125% in this setting see screenshot. this make the windows default fonts in all programs larger.
when set to 100% blur do not happen in high dpi mode in SO 1. but with high dpi monitor, all need set to more than 100%, because then overal windows fonts are too small to read on a 4 K Monitor. |
now the update to 3.1 let all show blur
microsoft write to the problem and the solution this. programmer need get the DPI value and draw depend on this https://support.microsoft.com/en-us/kb/2900023 Symptoms |
Hi Benny,
Doesn't look like you got much help on this one. I'm currently using Studio One 2 and I'm actually thinking of upgrading to Studio One 3 but I'm checking out a few other DAWs before I do. One of the things I want is a DAW that's got high-DPI GUI, and S1 v3 does really well in this respect. In fact, I think most DAW manufacturers have introduced new high-DPI GUIs in their latest releases, although some look much better than others. Cakewalk were one of the first, and Sonar looks great, but a little cluttered compared with S1. I was told that Digital Performer had a great GUI but in Windows it looks pretty bad, with very small blurry text, but I might have missed a setting here, like in S1. Bitwig too has a lovely GUI. Basically, they all make the older version of S1 look pretty bad on a full HD display. Anyway, I think the problem you're having is that Presonus might not have put the work in to make EVERY graphical element work perfectly in high-DPI mode, and it looks like the midi editor is one such area. I might be wrong, but seeing as the rest of the software looks great, I'd assume this to be the case. Is it really such a big problem as you're making out? Or have you found a solution? Cheers Karl |
Now with 3.1 update all is blur, see also in compare to the browser view in picture i attach. forum allow only 800*600 size, so it is so small. when i disable DPI scaling all is very small. I buy reaper and disable DPI scaling. reaper have same problems as S1. But in reaper 5 Fonts are larger and can better read with DPI Scale off. In S1 3 i miss much features and price is very high. I see what the future bring for S1. If the image i upload is not in the browser page image not sharp you have zoom in browser active. ctrl+mousewheel zoom in browser. if browser image is blur too you can download it and show in image viewer. s1 look as i have old CRT Monitor attach.
I sit not so near before computer, because i have always a midi keyboard before monitor. so i need 125% for Full HD Edit: in firefox the image is always in browser zoom up. I need 2 steps scale down always, to see image at correct sharp and size |
I see the new 3.5.4 do this ok. but i buy now a 27 Zoll monitor, because my old monitor is broken and i buy a small computer keyboard that i put on my midi keyboard. so i can more near to computer monitor and i have setting 100% now. so can see more. its possible after a little learning to write fast as before, and it is possible to play good with midi keyboard too. i need long time to find this solution to use a normal key midi keyboard. only 4 pads can reach and some sliders and buttons cant reach. the endless knobs are on left side and can reach. the start stop forward rewind buttons can reach too. but i mostly need them not.
