Hi, Just downloaded the trial, when I try to browse to an MP3 it is not visible and I can not drag it onto an audio track. I'm using the demo which should allow this ? MP3 spec below.
Thanks
Format : MPEG Audio
File size : 3.33 MiB
Duration : 3mn 38s
Overall bit rate mode : Constant
Overall bit rate : 128 Kbps
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Duration : 3mn 38s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel count : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 3.33 MiB (100%)
by jpettit on Thu Nov 27, 2014 9:18 pm
viewtopic.php?f=151&t=1037
Does not look like it works in demos.
Good time to get a supported version while they are on sale.
by colossal on Fri Nov 28, 2014 6:07 am
Its a good time to buy but it sucks that the full featured demo is not full featured and doesn't bode well.
Thanks for the response.
by cristofe on Fri Nov 28, 2014 11:18 am
The demo IS full featured. MP3 support is an ADDON:
MP3 Converter is an extension that adds professional-quality (up to 320 kB/s) MP3 encoding and drag-and-drop MP3 decoding to Studio One Artist 2.6.2 and higher. U.S. pricing: MP3 Converter $9.99.
by colossal on Fri Nov 28, 2014 1:48 pm
OK, that makes more sense.
Thanks
by colossal on Tue Dec 02, 2014 3:30 am
Back again, all the info says that producer should be able to import MP3, the addon is for artist to give you that functionality.
Something is not quite right.
by matthewgorman on Tue Dec 02, 2014 8:25 am
mp3 is the only functionality that does not work in the Pro demo. There is a licensing fee for mp3 encoders, which is probably why it is not included in a free trial.
by meangene31 on Tue Dec 02, 2014 8:38 am
If you have to use an MP3 just re capture it, or if you can convert the MP3 to a wave file, waves drop right in. Our singer is on Artist and he has just re-captured any MP3's if he had to import it into a track. He is using an iTwo Audiobox, plugged his phone into the iTwo input hit play/record and captured. We use that as a temp work around for scratching ideas and fast sharing.
But with the sale going on NOW is a perfect time to upgrade. I just downloaded Pro yesterday :) lots of extra goodies well worth the upgrade.
Mean Gene
PreSonus RM32Ai, QSC K12's, Ksubs, KW112's
Fractal Axe FX II XL, Atomic CLR Neo cabs
Two Rock Sensor, Aracom Evolver
Baker B1, b3 SL, Ibanez TM10
Roland TD9
PreSonus Fader Port, iTwo Audio Box, Studio One 2 PRO
MacbookPro, Lenovo 20 control
by davlet on Sun Jan 20, 2019 2:57 am
Anyway MP3 import in Studio One 4 is VERY SLOW
This is UNSUFFERABLE!
Studio 192 + Digimax DP88
Pro Tools 2018, Studio One 4
Hackintosh Intel Core i7 975, 12Gb RAM, Radeon HD 6870, MacOS Sierra
