Studio One 4.5 Signal Flow
Posted: Wed May 20, 2015 10:26 pm
by jpettit
Studio One 4.5 Signal Flow:
Description/disclaimers:
This picture is not a complete schematic of all possible flows as that is not practical with software flow due to logic or conditional flows such as Native Low Latency (Green Z) or Hardware monitoring flows (Blue Z)
This is not an official document from Presonus but meant to help understand the standard flow for routings, control and gain staging purposes. It was made through observations using Presonus signal generators, meters, and scopes.
As always, if anyone finds an error I will be glad to update the flow.
The primary flow is left to right and Audio and MIDI flows have been separated for ease of reading.
4.5 Signal Flow.pdf
(419.08 KiB) Downloaded 781 times
See the attached PDF for a printable version.
Re: Studio One V3.0 Signal Flow
Posted: Fri May 22, 2015 10:42 pm
by Daw Stew
Thanks for doing this Jeff. I had your v2 wallpaper as my desktop screen and it has proven useful. I shall do the same with this
Posted: Tue Jun 09, 2015 9:09 am
by Resonant Serpent
Thank you!
Posted: Tue Jun 09, 2015 6:26 pm
by sirmonkey
jpettit wroteThe new to 3.0 are circled in Red.
.....(screenshot of S1ver routing)...
Nice! Not that I can completely wrap my head around all of that...but that diagram may come in handy for many.
* Also, I still disagree with the OP on one point...I think there are good reasons that Busses and FX Channels are differentiated from each other. ** But his post was thoughtful and constructive.
Posted: Sat Nov 07, 2015 6:33 pm
by jpettit
Studio One 3.1 Signal Flow.
Removed new capability circles and added best place to export from Studio One to the diagram
EXPORTING AUDIO STEMS/CHANNELS for Various Reasons:
• Song Export Stems / Channels:
o Any channels including bus or FX channels
o File length equals range selected in export
o Includes all upstream processing (Channels inserts FX, Event FX, Event envelopes, Channels Fader level/pan, Mutes)
o Does NOT include Master channel settings: (Fader level, Inserts)
• Song Export Stems / Tack, or Song Export Mix down:
o Must be a track ( no bus or FX channels)
o Includes The entire signal chain including master settings: (Channels inserts FX, Event FX, Event envelopes, Channels Fader level/pan, Mutes, Master channel settings: (Fader level, Inserts)
• Drag a track event to a Studio One Browser/Folder: (example: My songs events audio)
o File length equals event size (no position within song)
o Includes the audio events + Event FX + Event envelope
o Does NOT include channel or master bus processing
• Alt+ Drag a track event to a Studio One Browser/Folder:
o Includes all upstream processing (Channels inserts FX, Event FX, Event envelopes, Channels Fader level/pan, Mutes) but not master bus processing
• (Select all events with Range Tool starting at zero) Drag a track event to a Studio One Browser/Folder: (example: My songs events audio)
o A file length equals the range selected (with independent events at the correct times within song)
• <Song folder>/Media:
o Raw unprocessed files that were recorded in Studio One or Imported media (Not Soundset based loops)
o Length equals event size
Posted: Mon Nov 09, 2015 11:19 am
by jpettit
Added useful detailed documentation on what, where and why to export Stems/Channel data to the signal flow diagram. (see post above)
Posted: Tue Dec 29, 2015 4:30 pm
by Daw Stew
Hi Jeff, could I ask you to create a 2560 X 1440 version of your signal flow file?
I currently use your 1920 X 1080 version but I've upgraded to a new QWHD 27" monitor which supports the higher resolution
Thanks
Posted: Tue Dec 29, 2015 10:47 pm
by jpettit
Here you go attached.
Re: Studio One V3.2 Signal Flow
Posted: Thu Mar 03, 2016 1:01 pm
by jpettit
Signal Flow updated to 3.2
See Original Post.
Posted: Tue May 28, 2019 10:02 am
by Daw Stew
Hi Jeff, will you be updating this Signal Flow diagram now that v4.5 has pre-fader metering and also the input gain section?
Posted: Tue May 28, 2019 12:20 pm
by jpettit
Yes, I am just pending a few reviews.
Due to the previous one getting too complex, I have separated audio and MIDI for starters.
Re: Studio One 4.5 Signal Flow
Posted: Sat Jun 22, 2019 9:34 am
by jpettit
The signal flow diagram has been updated to 4.5.
For readability purposes, the signal has been separated into Audio and MIDI pages.
As usual, if you detect an error I will be glad to update the diagram.
Posted: Sat Jun 22, 2019 10:10 am
by themaartian
#YAEC
Yet Another Excellent Contribution
Many thanks!
Posted: Wed Jun 26, 2019 5:41 am
by solis1
jpettit wroteStudio One 4.5 Signal Flow:
This picture is not a complete schematic of all possible flows as that is not practical with software flow due to logic/conditional flows such as Native Low Latency (Green Z) or Hardware monitoring flows (Blue Z)
4.5 Signal Flow.pdf
Thank you so much!!
Posted: Tue Jul 09, 2019 4:28 am
by lestervandewalle2
Awesome, I've been looking all over for this :thumbup:
Posted: Sun May 24, 2020 1:46 pm
by wolfjames
Under the Bus Channel shouldn't the second "pre-fader send/pan" be "post" instead of "pre"
This is a great reference. Thanks!
Posted: Sun May 24, 2020 3:27 pm
by jpettit
wolfjames wroteUnder the Bus Channel shouldn't the second "pre-fader send/pan" be "post" instead of "pre"
Yes.
Posted: Thu Jun 04, 2020 11:35 am
by davidgroeneveld
You made that??? How long did that take???
Posted: Thu Jun 04, 2020 12:41 pm
by jpettit
I have been doing them since 2.0. There are thousands of questions about routing and they help answer them for many in the community. Probably 10-20 hours per major version.
There is always the caveats of if you see something wrong, I will update it.
Posted: Sat Mar 06, 2021 10:24 am
by bassface
Tis is really great Jeff. It makes the maze a lot clearer, Thanks.
