Studio One 4.5 Signal Flow:
Description/disclaimers:
This picture is not a complete schematic of all possible flows as that is not practical with software flow due to logic or conditional flows such as Native Low Latency (Green Z) or Hardware monitoring flows (Blue Z)
This is not an official document from Presonus but meant to help understand the standard flow for routings, control and gain staging purposes. It was made through observations using Presonus signal generators, meters, and scopes.
As always, if anyone finds an error I will be glad to update the flow.
The primary flow is left to right and Audio and MIDI flows have been separated for ease of reading.
4.5 Signal Flow.pdf
(419.08 KiB) Downloaded 781 times
See the attached PDF for a printable version.
SPECS: Win 11 23H2, 18 Core i9: 32Gb DDR4 ram, 42" 4K monitor, StudioLive 24/16, Faderport16, Central Station Plus, Sceptre 6, Sceptre 8, Temblor T10, Eris 4.5, HP60, Studio One Pro latest, Test Platforms Reaper latest, Cakewalk latest
by Daw Stew on Fri May 22, 2015 10:42 pm
Thanks for doing this Jeff. I had your v2 wallpaper as my desktop screen and it has proven useful. I shall do the same with this
by Resonant Serpent on Tue Jun 09, 2015 9:09 am
Thank you!
by sirmonkey on Tue Jun 09, 2015 6:26 pm
jpettit wroteThe new to 3.0 are circled in Red.
.....(screenshot of S1ver routing)...
Nice! Not that I can completely wrap my head around all of that...but that diagram may come in handy for many.
* Also, I still disagree with the OP on one point...I think there are good reasons that Busses and FX Channels are differentiated from each other. ** But his post was thoughtful and constructive.
Atari 5200, 64K RAM S1PRO Radio Shack Cassette Recorder w/internal Mic, and too many plugins.
by jpettit on Sat Nov 07, 2015 6:33 pm
Studio One 3.1 Signal Flow.
Removed new capability circles and added best place to export from Studio One to the diagram
EXPORTING AUDIO STEMS/CHANNELS for Various Reasons:
• Song Export Stems / Channels:
o Any channels including bus or FX channels
o File length equals range selected in export
o Includes all upstream processing (Channels inserts FX, Event FX, Event envelopes, Channels Fader level/pan, Mutes)
o Does NOT include Master channel settings: (Fader level, Inserts)
• Song Export Stems / Tack, or Song Export Mix down:
o Must be a track ( no bus or FX channels)
o Includes The entire signal chain including master settings: (Channels inserts FX, Event FX, Event envelopes, Channels Fader level/pan, Mutes, Master channel settings: (Fader level, Inserts)
• Drag a track event to a Studio One Browser/Folder: (example: My songs events audio)
o File length equals event size (no position within song)
o Includes the audio events + Event FX + Event envelope
o Does NOT include channel or master bus processing
• Alt+ Drag a track event to a Studio One Browser/Folder:
o Includes all upstream processing (Channels inserts FX, Event FX, Event envelopes, Channels Fader level/pan, Mutes) but not master bus processing
• (Select all events with Range Tool starting at zero) Drag a track event to a Studio One Browser/Folder: (example: My songs events audio)
o A file length equals the range selected (with independent events at the correct times within song)
• <Song folder>/Media:
o Raw unprocessed files that were recorded in Studio One or Imported media (Not Soundset based loops)
o Length equals event size
by jpettit on Mon Nov 09, 2015 11:19 am
Added useful detailed documentation on what, where and why to export Stems/Channel data to the signal flow diagram. (see post above)
by Daw Stew on Tue Dec 29, 2015 4:30 pm
Hi Jeff, could I ask you to create a 2560 X 1440 version of your signal flow file?
I currently use your 1920 X 1080 version but I've upgraded to a new QWHD 27" monitor which supports the higher resolution
Thanks
by jpettit on Tue Dec 29, 2015 10:47 pm
Here you go attached.
by jpettit on Thu Mar 03, 2016 1:01 pm
Signal Flow updated to 3.2
See Original Post.
by Daw Stew on Tue May 28, 2019 10:02 am
Hi Jeff, will you be updating this Signal Flow diagram now that v4.5 has pre-fader metering and also the input gain section?
by jpettit on Tue May 28, 2019 12:20 pm
Yes, I am just pending a few reviews.
Due to the previous one getting too complex, I have separated audio and MIDI for starters.
by jpettit on Sat Jun 22, 2019 9:34 am
The signal flow diagram has been updated to 4.5.
For readability purposes, the signal has been separated into Audio and MIDI pages.
As usual, if you detect an error I will be glad to update the diagram.
by themaartian on Sat Jun 22, 2019 10:10 am
#YAEC
Yet Another Excellent Contribution
Many thanks!
Intel i9, 32 GB RAM, 7 TB SSD Win 11 Pro PreSonus Studio 1810c
Studio One 6 Pro MuseScoreMelodyne 5 Studio Acoustica Pro 7 Guitar Pro 8
Gig Performer 4 NI S61 MK3 Focal Shape 65 Beyerdynamic DT 880 Pro, DT 770 Pro
by solis1 on Wed Jun 26, 2019 5:41 am
jpettit wroteStudio One 4.5 Signal Flow:
This picture is not a complete schematic of all possible flows as that is not practical with software flow due to logic/conditional flows such as Native Low Latency (Green Z) or Hardware monitoring flows (Blue Z)
4.5 Signal Flow.pdf
Thank you so much!!
Studio One Professional 64 bit
macOS Mojave (10.14.4) (Hackintosh)
Core i7-8700K
32 GB RAM
1 TB SSD - Samsung EVO 960 + 4 TB HDD WD Black
Audient ID14 audio interface
by lestervandewalle2 on Tue Jul 09, 2019 4:28 am
Awesome, I've been looking all over for this :thumbup:
by wolfjames on Sun May 24, 2020 1:46 pm
Under the Bus Channel shouldn't the second "pre-fader send/pan" be "post" instead of "pre"
This is a great reference. Thanks!
by jpettit on Sun May 24, 2020 3:27 pm
wolfjames wroteUnder the Bus Channel shouldn't the second "pre-fader send/pan" be "post" instead of "pre"
Yes.
by davidgroeneveld on Thu Jun 04, 2020 11:35 am
You made that??? How long did that take???
Windows 11 Pro, I7 9700F 3 GHz, 16Gb RAM, Steinberg UR44, Faderport 16, Faderport II, ATOM SQ, Studio one 6 most recent version.
by jpettit on Thu Jun 04, 2020 12:41 pm
I have been doing them since 2.0. There are thousands of questions about routing and they help answer them for many in the community. Probably 10-20 hours per major version.
There is always the caveats of if you see something wrong, I will update it.
by bassface on Sat Mar 06, 2021 10:24 am
Tis is really great Jeff. It makes the maze a lot clearer, Thanks.
