Thanks in advance for any help and advice!
I've been using Studio One Artist for a while now, and I've used it with my Roland UA-22 Duo-Capture EX before. But just yesterday, I booted it up and the input selections on the Audio I/O Setup were not appearing and I could not select the inputs (refer to photo below)! - Preferences > Audio Setup > Song Setup > Audio I/O Setup The interface still works with my computer - it's able to connect to my monitors and plays music fine from Spotify. Embarrassingly, I had to use Garageband to record some urgent tracks - the interface worked fine with it. So I've narrowed it down to Studio One being the issue. I've reinstalled my interface's driver and updated Studio One, restarted my system multiple times, switched USB ports - all to no avail. Would appreciate some advice on this, thank you! ====================== macOS Monterey 12.0.1 Studio One Artist 2.6.5.30360 OSX x64 Roland UA-22 Duo-Capture EX |
SwitchBack wroteHi and welcome to this forum Thanks for the quick reply! I've checked my settings - Studio One has access to my microphone but still no inputs |
SwitchBack wroteAlso note that in Studio One on macOS you have the option to select different interfaces for inputs and outputs. Maybe toggle your selection (and back) and restart? Yes this worked!! Thanks so much - I didn't know you could use multiple interfaces at the same time on a Mac! The problem was that my computer was reading the inputs and outputs as 2 separate devices, and Studio One was only seeing the device with the outputs. So I had to combine these 2 into an aggregate device (refer below) and use that in Studio One instead. Thanks for the help!! Watched this video by Sam Loose that was super useful - https://www.youtube.com/watch?v=UYBBlqtx9K4&t=54s |
SwitchBack wroteYou shouldn't need that. Hmm. How do i do that in Studio One? |
First of all the problem isn't with Studio One, the problem is with the installation of the interface in macOS. The interface should install and show up as a single 2x2 interface but it doesn't. So that needs to be looked at, with the help of AU maybe.
As for Studio One: On the start page click on 'Configure Audio Device...'. It opens a window where you can set your playback device and your recording device. Until the driver installation is sorted set the AU-22 outputs as your playback device and the AU-22 inputs as your recording device (in that order). No aggregation needed. Or maybe not. Looking at your posts I see you're still on Studio One v2.6.5. Looks like that version didn't have the 2-interface option yet. Is that version even supported for Monterey? |
SwitchBack wroteFirst of all the problem isn't with Studio One, the problem is with the installation of the interface in macOS. The interface should install and show up as a single 2x2 interface but it doesn't. So that needs to be looked at, with the help of AU maybe. I've reinstalled my interface driver, but it still didn't fix the issue. Pardon my ignorance, but what is AU? Yeah my version is 2.6.5. Mostly works fine - maybe time to upgrade |
