Pre 3.5 Zero Latency/ Tape Style Monitoring Handbook
Posted: Sat Jul 05, 2014 2:19 pm
It is very important to always describe the following when describing monitoring questions of issues:
Options
1) ZLM State
2) Tape Style State
3) Monitor State
Scenarios
1) In the Box Non ZLM Monitoring / Soft Instrument
2) In the Box ZLM Monitoring / Real Instrument
3) Out of Box Monitoring / Real Instrument
Behaviors:
1) Record Meters
2) Live Audio Monitoring
3) Existing track Audio Monitoring
Thanks
Updated with 3.3.1 procedures and pictures.
This is just a few pages from the Zero latency Handbook (See PDF attached in this post).
Please see the 8 page PDF attached below if you want to learn the how to use it or how it works..
How do you know if you have Zero Monitoring Capabilities
1) You will see a “Z” underneath the hardware interface icon on the start page.
2) You will see the Z icon in your Audio Channels (if Cue mix is set on the main out), and in any Cue mix (if cue is set for your non main outs)
Create cue mixes for monitoring any "Z" mix.
5.10.1 Creating a Cue Mix Output
In Studio One, it is possible to quickly and easily create multiple cue mixes. A cue mix is separate from the main mix and is usually provided to musicians for monitoring purposes during recording.
For instance, when recording vocals, the engineer and vocalist will probably want to hear
different mixes. Most vocalists want to hear more of their vocals in the mix, possibly with some
reverb to make it sound natural, while the engineer might focus on how the performance
balances with the rest of the mix.
The first step in building a cue mix is to create another Output Channel. To do this, open the
Song/Song Setup/Audio I/O Setup menu in a Song, switch to the Outputs tab, and add a new
Stereo Output channel. Next, specify that this output is a cue-mix output by clicking on the
channel’s Cue Mix checkbox. You can create as many cue mixes as your audio interface has
available stereo outputs.
Enable Z
Click the "Z" On, either on the channel for main outputs or on the cue mix. You will hear the "Z" latency in your corresponding output when you do this.
"Z" Monitoring
The procedure is for recording or auto punch in recording mode:
1. Record-enable AND Monitor-enable the new track(s).
2. Verify the "Z" is set for you monitoring cue.
3. You will hear the source at a "Z" latency level. (You are hearing the monitoring from the hardware)
4. Record the track listening to the "Z" cue mix.
5. To hear the recorded track turn off "Z" or the Monitor button.
"Z" Monitoring with (Tape Style)
If you are using the Tape Style monitoring, use this procedure:
1. Turn Tape Style monitoring on in the Options/Advance/Console
2. Record-enable the new track (Disable the Monitor button if you want to use auto punch in)
3. Verify the "Z" is set for you monitoring cue.
5. In Tape Style, because the Monitor button is off you will hear the recorded track on playback.
The PDF Handbook has more includes more details like Tape Style Monitoring vs. Non Tape Style Monitoring, Monitoring with Effects (optional),Signal Flow Reference, How The Delays are Handled by Studio One, Technical References. Be sure to check it out if you need more information.
Monitoring Table
Options
1) ZLM State
2) Tape Style State
3) Monitor State
Scenarios
Behaviors:
1) Record Meters
Thanks
Enable Z
"Z" Monitoring
Monitoring Table
