81 postsPage 1 of 5
1, 2, 3, 4, 5
It is very important to always describe the following when describing monitoring questions of issues:
Options
1) ZLM State
2) Tape Style State
3) Monitor State
Scenarios
1) In the Box Non ZLM Monitoring / Soft Instrument
2) In the Box ZLM Monitoring / Real Instrument
3) Out of Box Monitoring / Real Instrument
Behaviors:
1) Record Meters
2) Live Audio Monitoring
3) Existing track Audio Monitoring
Thanks
Updated with 3.3.1 procedures and pictures.
This is just a few pages from the Zero latency Handbook (See PDF attached in this post).
Please see the 8 page PDF attached below if you want to learn the how to use it or how it works..
How do you know if you have Zero Monitoring Capabilities
1) You will see a “Z” underneath the hardware interface icon on the start page.
2) You will see the Z icon in your Audio Channels (if Cue mix is set on the main out), and in any Cue mix (if cue is set for your non main outs)
Create cue mixes for monitoring any "Z" mix.
5.10.1 Creating a Cue Mix Output
In Studio One, it is possible to quickly and easily create multiple cue mixes. A cue mix is separate from the main mix and is usually provided to musicians for monitoring purposes during recording.
For instance, when recording vocals, the engineer and vocalist will probably want to hear
different mixes. Most vocalists want to hear more of their vocals in the mix, possibly with some
reverb to make it sound natural, while the engineer might focus on how the performance
balances with the rest of the mix.
The first step in building a cue mix is to create another Output Channel. To do this, open the
Song/Song Setup/Audio I/O Setup menu in a Song, switch to the Outputs tab, and add a new
Stereo Output channel. Next, specify that this output is a cue-mix output by clicking on the
channel’s Cue Mix checkbox. You can create as many cue mixes as your audio interface has
available stereo outputs.
Enable Z
Click the "Z" On, either on the channel for main outputs or on the cue mix. You will hear the "Z" latency in your corresponding output when you do this.
"Z" Monitoring
The procedure is for recording or auto punch in recording mode:
1. Record-enable AND Monitor-enable the new track(s).
2. Verify the "Z" is set for you monitoring cue.
3. You will hear the source at a "Z" latency level. (You are hearing the monitoring from the hardware)
4. Record the track listening to the "Z" cue mix.
5. To hear the recorded track turn off "Z" or the Monitor button.
"Z" Monitoring with (Tape Style)
If you are using the Tape Style monitoring, use this procedure:
1. Turn Tape Style monitoring on in the Options/Advance/Console
2. Record-enable the new track (Disable the Monitor button if you want to use auto punch in)
3. Verify the "Z" is set for you monitoring cue.
5. In Tape Style, because the Monitor button is off you will hear the recorded track on playback.
The PDF Handbook has more includes more details like Tape Style Monitoring vs. Non Tape Style Monitoring, Monitoring with Effects (optional),Signal Flow Reference, How The Delays are Handled by Studio One, Technical References. Be sure to check it out if you need more information.
Monitoring Table
Zero Latency Monitoring Hand book V3.3.1V2.pdf
(1.26 MiB) Downloaded 1196 times
by bvandy on Sat Jul 19, 2014 6:24 pm
Thanks a lot for posting this. I have such a hard time wrapping my head around this topic.
I use a SL 16.4.2 as my recording interface with Studio One 2. Shouldn't I be able to see the "Z" switch on the cue mix block on the track fader? I only get a activation switch and the lock switch on the cue mix block in the track.
Any info that you can provide would be greatly appreciated. Thanks again for the post.
Cheers,
Vandy
MacBook Pro 17" 2.4Ghz Laptop - Mavricks OS - System drive: Samsung 840 Pro SSD - Internal Audio Drive: Hitachi 7200 HDD - 16GB RAM
My Book Studio external drive
Studio One Pro
16.4.2 Classic
FaderPort
KB37
by Scardanelli on Sun Nov 02, 2014 9:47 am
Can anyone tell me if there are Zero latency options for Core audio in OS X? I was at a friend's studio yesterday and he runs a RME HDSP Interface on PC, and has the Z appear in the Studio One mixer. I run on OS X, using a Metric Halo ULN-2 - this has onboard DSP and therefore should be perfectly capable of running with the zero latency monitoring in S1 - of course I can and do use the DSP for running the Mio Mixer, which allows me zero latency monitoring, but this happens outside of S1 and therefore is another layer to work with. The thought that I could control the monitoring within the S1 mixer would be fabulous! Any thoughts or answers please?
Simon
Mac Pro - 6 Core 3.46 GHz - 12GB RAM, Metric Halo ULN-2 (2). OSX El Capitan 10.11.4. Studio One V3.3 Notion 5
http://www.scardanelli.com
http://www.Vi-ViD.com
by -Luis- on Sun Nov 02, 2014 1:48 pm
No, zero latency monitoring in Studio One with a third party audio interface is only possible in Windows.
by MisterE on Mon Jan 19, 2015 9:39 am
I have a Mackie Onyx Blackbird interface running under Windows and have been pleasantly surprised since Day One that I seem to have "zero" (or something so small it may as well be zero) latency whether I record audio, virtual instruments, or external instrument (a.k.a. hardware synths) tracks. There is no lag heard when recording and everything lines up fine. When I first assembled my system I was expecting to have to fight latency but have never had to.
I have my buffer set low, but not incredibly low (128; have not touched it in six months and everything's honky-dory).
However, there is no Z appearing in the mixer on any tracks.
I'm not sure what my point is, other than to say you can have a fabulous user experience with or without the Z ... probably depending on your interface and how tuned your overall system is.
Home-rolled i2500 PC with Win7 64-bit OS, Samsung 840 Pro SSD OS drive, 1 TB WD Black Audio Drive, WD sample and backup drives and 16 GB RAM | Mackie Onyx Blackbird interface | 2 Presonus Eurekas | Presonus Monitor Station | Behringer Truth B3031A Studio Monitors | CAD M9 mic | Avantone CL40 stereo mic | Roland Jupiter 50 | PRS Custom 24 | 1964 Martin D18 | Taylor 612C
by mrpicholas on Mon Jan 19, 2015 9:31 pm
Or on how awesome you are.
MacBook Pro 2 GHz Intel Core i7 with 16GB RAM & OS 10.9.5. Studio One Professional 3.5, Notion 5, 2x PreSonus Firestudio Project Interfaces, PreSonus ACP88, PreSonus Sceptre S6, FaderPort, Melodyne Editor 2.1.2, Waves Gold Bundle 9, Nomad Factory Integral Studio Pack, Native Instruments Kore 2 & Komplete 6 (Kontakt 5), IK Amplitube 3, AAS String Studio & Ultra-Analog VA2. Faber-Castell #2 Pencil
by kevinsmith on Fri Feb 06, 2015 7:16 pm
OMG, I have been wondering what that Z was all about - thank you!
by rokko101 on Sat Feb 28, 2015 9:03 am
Hi there and thanks for the info.
I have a problem with Zero Latency in Studio One / Firestudio Project.
When I enable Zero Latency to monitor a track I can no longer hear pre-recorded audio (it's like muting the track and hearing only live input) so punching in becomes difficult of impossible as previously recorded audio can't be heard.
I hope someone can help.
OSX 10.13, Mac Pro 2012 , Mac Mini 2012, Studio One v. 4.1, Presonus Studio 192, AudioBox iOne.
by jpettit on Mon Mar 02, 2015 11:43 am
rokko101 wroteHi there and thanks for the info.
There could be many differences on how you set up your outputs.
Can you attach a few pictures to explain your set up in more detail?
Remember Z monitoring only occurs on outputs that you have specified as Cue type outputs.
by rokko101 on Mon Mar 02, 2015 12:26 pm
Hi.
My actual setup is pretty simple. FSP / Studio One.
1.- Try recording a track with ZL enable (Routed to a CUE enable output). Everything works. No Latency and audio is recorded properly.
2.- Now try to hear what you've recorded without disabling monitoring. You'll hear nothing. The armed track is unable to blend direct input and playback. (Unless you disable monitoring or disable ZL for the used track).
There maybe some workarounds but i'd appreciate if Presonus includes the option "Not to mute playback when monitoring" also for ZL enabled tracks.
by jpettit on Mon Mar 02, 2015 2:57 pm
Got to run so no time for more details but do you by chance have Audio Track monitoring mutes playback ( tape style ) set in your advance preferences?
by rokko101 on Tue Mar 03, 2015 2:21 pm
"Audio Track monitoring mutes playback (tape style) " can be disabled only if Zero Latency is off.
Once working on a ZL enabled track it won't follow this behavior and it's stuck muting playback.
I've contacted Presonus so they can check if it's a bug (or bizarre feature).
The need to enable, disable monitoring all the time to hear playback or live signal (blending both is what is expected) is a no go in my handbook.
Studio One is a great piece of software and I'm really in love with it, make no mistake. Maybe this is the only odd behavior i've encountered.
by jasoncogswell on Tue Mar 03, 2015 4:01 pm
rokko101 wrote"Audio Track monitoring mutes playback (tape style) " can be disabled only if Zero Latency is off.
Ok you're saying if you switch the tape style button and zero latency button in the right order it will work? I'm struggling with this with an 1818vsl, last night I swear it worked properly for a min, but then went to punch in a guitar and could not get zl monitoring to work without muting playback of the track I wanted to punch on. Like I said it worked for a minute, then I clicked around the monitoring buttons just trying to figure the settings out and couldn't get it back. Got frustrated and quit the session.
S1 3 PRO 64bit, Win 10 64bit on dell xps8900 i7 16gb, Glyph studio raid 6tb Sceptre S8 monitors, temblor t10 sub, Faderport Studio 192 + 2 dp88's, 2 Warm WA-412's
by rokko101 on Thu Mar 05, 2015 7:02 pm
Zero Latency monitoring will mute playback no matter whether you uncheck the option not to do so. Which sounds like a bug.
I've reported it to Presonus. Let's hope they'll sort it in a future release.
by jpettit on Thu Mar 05, 2015 9:55 pm
Page 5 of the hand book tells you to create a Cue Bus. Then Monitoring will work on play and record.
by rokko101 on Thu Mar 05, 2015 10:23 pm
If you create 2 Cue mixes for the same output you'll hear 1) the direct Zero Latency signal and 2) a delayed copy (according to buffer size) at the same time. This is plain wrong and unusable even if this allows to hear playback (attenuated by a few dBs for some reason).
So i'm afraid to say this is not a solution at all and still consider this is a bug that needs to be addressed by Presonus in a future release.
by jBranam on Fri May 08, 2015 9:24 pm
thnx for the info. just got me a new interface and it is the only one that has the "Z" and i was wondering since i had not seen it before. cheers
"we watch every day for the bus
and the driver would say
that's where lunatics stay
i wonder if he's talkin' 'bout us"
Ryzen 5 1600 : Asrock AB350M Pro4 : 32Gb 2400 RAM : Win10 64bit : Presonus 192 Mobile : Audient iD4 : Ultrasone 900 Pro : Blue Lola : Samson Resolv 50a : Ik Multimedia iLoud :
Knot Hardly Productions
¯\_ { ͡• ͜ʖ ͡•} _/¯
by jpettit on Tue Jun 30, 2015 10:04 am
Version 3.0.1 Version of the Zero Latency Handbook.
- All revalidated
- Added Tape Style monitoring procedure and comparison table
- Rearranges to get the the "how to" quicker and less theory
- Graphics updated to 3.0.1 and Flow diagram simplified
Zero Latency Monitoring Hand book V3.0.1.pdf
(1.66 MiB) Downloaded 1365 times
by garyrennert on Thu Aug 06, 2015 11:11 am
Thank you for this!
by vahevahe on Wed Jan 13, 2016 12:49 pm
I wish we were able to use Zero latency with 3rd party converters. The apogee maestro is very bare bones. Embarrassing for 2016
Mid 2010 Mac Pro
OSX 10.10.4
16 gigs or RAM
S1 Pro 3.0.1
Apogee Symphony
81 postsPage 1 of 5
1, 2, 3, 4, 5
