Hello,
I'm using an AKAI MPK mini with studio one.
In the v3, I was able to create a mapping with the pads of the mini MPK (after several hours of frustration due to the MPK), and then re-use this mapping with the different sounds bank of Impact.
When installing the v4, the default mapping was carried over, with the proper note, but now, when I select a sound bank after, it revert to the default studio one setting.
Can anyone help me, I would like to avoid having to modify every single sound bank to make them match my pads.
Best regards,
David
by snb1 on Thu Jan 17, 2019 7:28 pm
I believe loading a new sound bank will loading what ever setting was stored with the preset. A work around would be to use two separate Impacts XTs. One for browsing sounds in different sound banks and one for your custom mapping. Then you'll be able to drag sounds from one instance of Impact XT to the other.
Studio One Pro 4.5.1 64 bit, Mac OS 10.12.6, Mac mini (Late 2012) 2.3GHz quad-core Intel Core i7 (Turbo Boost up to 3.3GHz) with 6MB L3 cache, Intel HD Graphics 4000, 16 GB ram, 240 GB OWC Extreme Pro 6G Solid State SATS Drive startup disk, 1 TB internal SATA Dive, (2x) 1 TB External Glyph Studio 7200RPM eSATA Drives, 500 GB External WD Drive
