Studio One is a wonderful DAW and I don’t find any problem in performing any required task , and if needed I get the necessary help through YouTube videos or other online resources. The only thing I couldn’t find an answer to is how can I adjust the volume on sections (only) of a MIDI track (not the audio automation) and not the whole track? The lower part of the MIDI editing window should enable add parameters including volume but I could not find it in the drop down list but Velocity for example is there and works well.
Any Studio One 3.5 expert’s help would be very much appreciated.
by snb1 on Thu Jan 17, 2019 7:15 pm
Using the velocity would be your best bet in this case. Set up a key commands to raise and lower the velocity of selected midi notes or events. So all you would have to do is select a midi event and use your key commands to either raise or lower the velocities. But make sure the velocity is linked to volume on your vsti.
Studio One Pro 4.5.1 64 bit, Mac OS 10.12.6, Mac mini (Late 2012) 2.3GHz quad-core Intel Core i7 (Turbo Boost up to 3.3GHz) with 6MB L3 cache, Intel HD Graphics 4000, 16 GB ram, 240 GB OWC Extreme Pro 6G Solid State SATS Drive startup disk, 1 TB internal SATA Dive, (2x) 1 TB External Glyph Studio 7200RPM eSATA Drives, 500 GB External WD Drive
