steve if you are on windows download it (right click 'save link as') ... then right click pdf file and "open with" a browser... Edge, Internet Explorer etc... it opens with both Google Chrome and Windows Edge fine here. cheers
Consistently Inconsistent Ryzen 5 1600 : Asrock AB350M Pro4 : 32Gb 2400 RAM : Win10 64bit Macbook Pro 13 : 10th Gen Quad i5 : 512Gb SSD and 1Tb Glyph Atom SSD : 16Gb 3733 RAM : Catalina 10.15.5 iPad Air 3rd Gen : 64Gb : A12 Bionic : 10.5 inch Presonus 192 Mobile : Audient iD4 Ultrasone 900 Pro : Blue Lola : Blue Mix-Fi : AKG 240 Studio Samson Resolv 50a : Ik Multimedia iLoud Knot Hardly Productions ¯\_ { ͡• ͜ʖ ͡•} _/¯ |
So, I've decided to track some guitars today to test out these features.
I have a saved FX chain that I have used in the past and like and I've loaded it into a track. My "Z" is green on my output folder and when I put the track into record and monitor, the Inserts all go green, so looking good. Only, I swear it's processing the whole effects chain twice - sounds terrible! If I look at the performance monitor, I see the plug ins listed as Monitoring FX, so all good there, and I also see them listed again as Inserts on the track, but if I disable them there, I lose them completely (in both areas). If I turn off the green "Z" in the output and try the old fashioned way, it sound normal, the way I would expect - aside for the latency now introduced by dropout protection. Any ideas? Cheers, Tim |
Only plug-ins 3 ms or less can be heard on the green Z path. Look at the performance monitor and see if they're doubling. They should be but you should only be able to hear one of the two.
If they are greater than 3 ms and you can only hear them on a bus but with the delay.
Thanks for the booklet JPettit. Trying to get my head around this. Now, whilst I seem to be able to have the track running at high latency (many plugins etc., a few virtual instruments), and I'm also able to play a VST synth (via Kontakt) at low latency whilst this is happening (ergo, the new feature must be working!?), I cannot choose "use native low latency monitoring" - it is greyed out, as the attachment will show.
If I choose the "enable low latency monitoring for instruments" - which is available, the clicks/pops return. From what I've read, the native low latency is the better option.... but unavailable for some reason? I'm likely to be missing the obvious. (i7 4770K, Windows 10 64 bit, Focusrite Clarett 8 Pre via thunderbolt for PC... ) ![]()
Studio One 5.1 - Windows 10 x64, Ryzen 5 5600x, 32GB DDR4 @3600
Adata M.2 500GB for OS, Gigabyte 1TB M.2 & Samsung 850 SSD x2 for Audio and Romplers. IIyama 40 inch LED monitor, Presonus Faderport 2 RME Raydat PCI-E, SPL Crimson Rev.3, Clarett 8 Pre USB Focal Twin 6BE monitors Numerous microphones from Audio Technica, AKG, SE Electronics, Neumann...and my favourite Mojave 301 FET. |
Thanks. This is very helpful.
aka "gesslr" or "george napier"
10 core iMacPro 1,1 | 64GB | OSX 10.15.6 | S1Pro 5.0.1 | MOTU I/O | Too Many Plug-ins | http://www.storyaudio.com FB: geo.napier3 PLEASE SUPPORT THESE FRs Video follows edit mode http://tinyurl.com/yc2gc9b3 Studio One Workspaces http://tinyurl.com/ybgfjpoj |
Jeff's excellent handbook document is the link at the top of this thread and yes, I can open it fine. Try again?
Skip
Skip
Speranza wrote1) I cannot choose "use native low latency monitoring" - it is greyed out, as the attachment will show. 1) First clarification. the second option is for people with hardware low latency to NOT use blue Z but use Green Z. It is not available to people who do not have hardware monitoring via Presonus 192 or Quantum series or an ASIO 2 DM driver. But then I look at you interface and I would think a TB interface would have ASIO DM drivers? I know RME does. To save you time though Green Z trumps them all. 2) This is the opposite behavior expected. We (you and/or the community) would have to start with a test song with the same Kontakt and samples and work up to a point we could replicate it.
jpettit wroteSperanza wrote1) I cannot choose "use native low latency monitoring" - it is greyed out, as the attachment will show. Jeff, thanks for the reply. So it's greyed out because I haven't the necessary hardware i.e. Presonus Quantum/192 etc. As for point 2, I'm even more confused....
Speranza wrotejpettit wroteSperanza wrote1) I cannot choose "use native low latency monitoring" - it is greyed out, as the attachment will show. 2) If I choose the "enable low latency monitoring for instruments" - which is available, the clicks/pops return Enabling LLM should NOT cause pops and clicks Need to get to the bottom of it by starting a new song and adding complexity until the wrong behavior starts.
I'll have to try it when I've more time to test that. Currently in between projects.
What is odd is that the feature is working. I can play a VST instrument at low latency, and the Green Z is lit. It's on maximum drop out protection, and the buffer setting I've chosen on the Focusrite Control Panel is 64 samples (equating to 3.23ms latency according to S1). Thanks for responding here. Perhaps I shouldn't look a gift horse in the mouth. It's working, so for now, I'll leave it as is and try to get to the bottom of it another time....
Good read on the booklet.
Should prove useful for future needs. Nice, Jeff. No issues. Enjoying three five.
S1 Pro 4.6.x, Laptop: VAIO i7, 8 core, Win 7 64x. Audio Interface: Audiobox 22 VSL, Audiophile 192 Controllers: Arturia Keylab 49 MkII, Novation SL25 MKII, Faderport 8, Roland JV-90, Roland GR-50, Roland Octapad, Akai MPD-18. MIDI Patchbay: MOTU 8x8, Monitoring: Mackie HR824, Yamaha HS-7, Mixer: Yamaha Promix 01, Rane HC-6.
Latest song releases on Bandcamp - Latest albums on iTunes LP's "Amber & Blue", and "Reasonable Approach" available on all major distribution music services. Simply search "James Conrad Tucker". All songs copyright. Be safe. |
Thanks for trying to help guys, much appreciated.
Tried a fw times downloading again but no joy. I've looked into it further and for some reason my tablet is downloading/seeing the file as a video file, not a pdf file! Jay ... I don't have the facility to right click and 'open as' cos I'm away from home and only have my tablet with me. It'll wait till I get back to France with my 'brand spanking new' PC - hoping for good things loading S1-3.5 onto a virgin machine (but not naive enough to expect plain sailing) wish me luck...... Regards
Windows 10 Pro/i7 6800k @3.4Ghz/16Gb ram. Studio One Pro, Melodyne Editor 4, Vocalign Project, Superior Drummer 3, Izotope N2-O8 and various other plugins. Focusrite Saffire Pro 40, Faderport, Focal Alpha 50's, Korg Pa3x, Korg Pad Kontrol, numerous guitars, basses & other antiquated outboard gear.
tshadgett wroteAh, I think I might have a clue. Yes splitters and analysis tools are not supported. (listed in the handbook)
I was even able to open it in iBooks on my iPad.
Steve Carter wroteHi Jeff...
Behringer Wing, iMac late 2015, Behringer X-Touch, X-Touch ONE, M-Air mr18, X-Air xr18, x32 with Dante/aes67, x32-rack with Dante/aes67, s16 and sd16 stageboxes, p16 monitor system, TurboSound iQ-speakers, Waves x-wsg with SoundGrid server, Motör 61, BCR-2000, StudioLive 24, FirePod 10, Apogee Ensemble, Alesis HD24, Studio One Pro v5, Notion 6, NI Komplete 11 Ultimate, Halion 6, Nuendo 10, Ableton Live 8 Suite, Reaper 4, misc Line6 gear/software, True Temperament Frets on basses and guitars, Korg Kronos, Roland vk-7, Behringer Deepmind 12, Behringer Neutron, Yamaha 02r.....
jpettit wroteHardware monitoring is slightly better than the low latency monitoring To clarify, I mean yes I have both and that the blue Z is a few ms less than the green Z. I always use the physical monitor button on the interface when tracking though. |
Just a matter if you want to hear the voice/instrument processed and reverb to help the performance.
BTW you should be see a 30% drop across the board on marginal CPU songs.
jpettit wroteJust a matter if you want to hear the voice/instrument processed and reverb to help the performance. I need more than processing / reverb to help my performance; more like a miracle ![]() |
jpettit wroteDo you think the key to this is 64 vs 32 bit Process Precision? It's tough to tell without more information. That's why I'm asking if anyone else can replicate the issue. |
