Hi.
My crossfaed is set to 10ms. Can I reduce so It automaticly becomes 5ms when I do a crossfade /Andreas |
Yes. The "Create Crossfades" action (if that action name is correct, not at the daw currently) has arguments where you can set the length and curve. If you want something different from the default, configure a macro with that action, set a different length, and replace the default crossfade key binding with the macro action.
