Apologies from the get go, I don't have much of an idea what I'm doing. I did enlist the help of Google first. The more I think about it, the more unlikely it seems, but would one be able to play through, say, a Line 6 Guitarport XT using their amp models and record the output via Studio One?
by dgkenney on Tue Sep 02, 2014 11:30 am
GuitarPort can work with other Windows audio applications that support ASIO, DirectSound or MME.
Per their description of the product I found on the web, you should be able to use S1 as a recording platform. Just set up the Line 6 driver in the Audio preferences.
Dan
It's all down hill from what's in front of the microphone. - Bob Olhsson
And yet everyone wonders why, alone in your room with a laptop and a bunch of plugins, you can't compete
S1/3 Pro 64
***Lenovo i5 @ 3.1ghz running Windows 10 x64 Pro with Syba PCI-Express 1394b/1394a (2B1A) Card, TI Chipset, SD-PEX30009
*** Levono E520 with SYBA SD-EXPC34-2F 1394A Firewire 2-Port ExpressCard *** Win 10 x64 Pro
***MOTU Ultralite AVB*** Audient ASP/880*** Digidesign Eleven Rack, PT 10*** Firestudio Mobile
by Brex781 on Thu Oct 16, 2014 7:52 am
I've used my POD X3 as an interface and it worked. It had a bit of latency though. I need to figure out how to fix that.
by cristofe on Thu Oct 16, 2014 2:40 pm
Yeah, not had the best of luck with Line6 ASIO drivers. I've gotten better results with Guitarports/UX-1's by using another audio interface and just using Gear Box as a VST plugin. Likewise, I've gotten better results with POD's just using them as outboard FX processors.
