When I pan a track hard left or right and it's output is set to Main, it stays that way. When I pan it and send it to a Mix Bus, the MB puts the audio back up the middle. Is there a way to set your Mix Bus so that when you send audio to it, the audio remains panned the way I set it in the track? Thanks in advance!
by matthewgorman on Thu Jul 07, 2016 6:15 am
If you are sending it via a send in the inserts panel, then you need to pan that send. Should be a small slider below the send level.
If you are sending via the output setting at the top of the channel fader, then it should follow the panning set on the track.
Matt
S1Pro V4
