Posted: Mon Jun 27, 2016 9:25 am
by Frederick Berry
Morning,if I only recorded 40 bars of an song,4 instruments how can extend without having to play all the parts again?
Re: Recording
Posted: Mon Jun 27, 2016 10:00 am
by mrpicholas
Simplest way is to select the existing tracks and hit "D" for duplicate. It should duplicate everything as recorded, immediately following the existing material.
Re: Recording
Posted: Mon Jun 27, 2016 10:28 pm
by Steve Carter
Hi Frederick....
You can select sections of the song track/s either by splitting or with the range tool and then copy & paste or click 'alt' and drag into the required position along the time line onto the same track/s or onto new tracks.
It may help to have 'snap' on whilst doing this.
For audio tracks, minor anomalies can usually be cleaned up by using Melodyne (if you have it) or use the crossfade facilities in the edit panel or. If you prefer, the arrangement screen - maybe zoomed in.
Regards....
