Studio One 3.2 Signal Flow.
Updates since 3.1:
1) added VCA remote control flows
2) added Mix FX remote gain control and crosstalk audio flow
Description/disclaimers:
This picture is not a complete schematic of all possible flows as that is not practical with software flows due to the relative ease of new flows.
This is not an official document from Presonus, but meant to help understand the flow for routings, control and gain staging purposes. It was made through observations using Presonus signal generators, meters and scopes. As always, if anyone finds an error I will be glad to update the flow.
In general the picture is an overview showing only one instance of each of the components. The primary flow is left to right and feedback flows are right to left.
See the attached PDF for printable version.
S1 RoutingScreen 3.2 Flow only.pdf
(1.14 MiB) Downloaded 242 times
To add your specs to your signature, click HERE
How To Get Your Issue Fixed
Community Training
Win 10 64-bit, 12 Core i7: 32Gb DDR4 ram, 40" 4K monitor, Studio 192, Faderport 8, Central Station Plus, Sceptre 6,Temblor T10, Eris 4.5, HP60, Line 6 UX2, Studio One Pro 3.4, Reaper 5.4, Sonar Platinum
by Daw Stew on Fri May 22, 2015 10:42 pm
Thanks for doing this Jeff. I had your v2 wallpaper as my desktop screen and it has proven useful. I shall do the same with this
by Resonant Serpent on Tue Jun 09, 2015 9:09 am
Thank you!
by sirmonkey on Tue Jun 09, 2015 6:26 pm
jpettit wroteThe new to 3.0 are circled in Red.
.....(screenshot of S1ver routing)...
Nice! Not that I can completely wrap my head around all of that...but that diagram may come in handy for many.
* Also, I still disagree with the OP on one point...I think there are good reasons that Busses and FX Channels are differentiated from each other. ** But his post was thoughtful and constructive.
Atari 5200, 64K RAM S1PRO Radio Shack Cassette Recorder w/internal Mic,
by jpettit on Sat Nov 07, 2015 6:33 pm
Studio One 3.1 Signal Flow.
Removed new capability circles and added best place to export from Studio One to the diagram
EXPORTING AUDIO STEMS/CHANNELS for Various Reasons:
• Song Export Stems / Channels:
o Any channels including bus or FX channels
o File length equals range selected in export
o Includes all upstream processing (Channels inserts FX, Event FX, Event envelopes, Channels Fader level/pan, Mutes)
o Does NOT include Master channel settings: (Fader level, Inserts)
• Song Export Stems / Tack, or Song Export Mix down:
o Must be a track ( no bus or FX channels)
o Includes The entire signal chain including master settings: (Channels inserts FX, Event FX, Event envelopes, Channels Fader level/pan, Mutes, Master channel settings: (Fader level, Inserts)
• Drag a track event to a Studio One Browser/Folder: (example: My songs events audio)
o File length equals event size (no position within song)
o Includes the audio events + Event FX + Event envelope
o Does NOT include channel or master bus processing
• Alt+ Drag a track event to a Studio One Browser/Folder:
o Includes all upstream processing (Channels inserts FX, Event FX, Event envelopes, Channels Fader level/pan, Mutes) but not master bus processing
• (Select all events with Range Tool starting at zero) Drag a track event to a Studio One Browser/Folder: (example: My songs events audio)
o A file length equals the range selected (with independent events at the correct times within song)
• <Song folder>/Media:
o Raw unprocessed files that were recorded in Studio One or Imported media (Not Soundset based loops)
o Length equals event size
Community Training
by jpettit on Mon Nov 09, 2015 11:19 am
Added useful detailed documentation on what, where and why to export Stems/Channel data to the signal flow diagram. (see post above)
Community Training
by Daw Stew on Tue Dec 29, 2015 4:30 pm
Hi Jeff, could I ask you to create a 2560 X 1440 version of your signal flow file?
I currently use your 1920 X 1080 version but I've upgraded to a new QWHD 27" monitor which supports the higher resolution
Thanks
by jpettit on Tue Dec 29, 2015 10:47 pm
Here you go attached.
Community Training
by jpettit on Thu Mar 03, 2016 1:01 pm
Signal Flow updated to 3.2
See Original Post.
Community Training
