30 postsPage 2 of 2
1, 2
The symbol in the opening graphic of this thread shows up when you change the BPM. Perhaps you slowed down the song to record a part that was hard to play or you decided the song was too fast or too slow.
AMD Ryzen 5600X CPU | Gigabyte B550 Vision D-P mobo | WD Black 2TB PCIe 4.0 NVME SSD | Crucial Ballistix 32GB 3600 mhz RAM | MSI Geforce 3060 Ti Gaming X | Win10 64-bit | S1 v6.0.2 | Mackie Onyx Blackbird interface | Korg M3 | Arturia Keylab 49 mkII
by David Mood on Mon Jan 19, 2015 5:41 am
No, I used pitch-shifting on that event.
This symbol seems to appear when you use pitch-shift or time-stretch on an event.
Win7 x64 SP1 / i7 2600K / 16 GB RAM / ATI Radeon HD 5450 / ASUS P8P67-M PRO MB
by MisterE on Mon Jan 19, 2015 9:27 am
Changing the beats per minute (BPM) must be a form of time stretching then, cause that symbol always shows up when I'm experimenting with different BPMs.
Try it.
Either that, or as many have already pointed out, the symbol is so tiny they just look similar.
by kensherwood on Mon Jan 19, 2015 10:27 am
From the pdf file that's available @ the thread Icon Symbol Legend, that symbol denotes "Clip being processed (Timestretch, Audio Bend, Sample Rate Change, etc.)". HTH.
• Studio One 3.0.0.33329 Professional
• Early 2009 Mac NOT "MAC"* Pro dual 2.26, 16 GB RAM, OS X Yosemite 10.10.2
• Dual Dell 2408WFP (1920x1200 px) monitors
• Samsung 840 EVO 250GB SSD, 6TB SoftRAID array
* https://public.wsu.edu/~brians/errors/mac.html
by Lawrence on Mon Jan 19, 2015 11:24 am
Yes. There are different ways that happens when that icon appears to show up just to let you know something is being processed.
- Pitching with Elastique' (Transpose or Tune)
- Stretching manually or with tempo change.
- Real time SRC happening because of a sample rate mismatch between the clip and the project.
- Audio Bend (which is stretching)
... and I suppose anything else that might happen like that, where the source audio file is being processed or changed in some way. In most cases (maybe not all, timestretch can run from a cache for example) it probably also means that those clips are using some real time CPU cycles that you can recover by bouncing the clip.
by robertgarrett on Wed Sep 16, 2015 7:27 am
1.Icons for tracks like logic and Cubase has
2.The fonts on the mix console are to small to
. Read making that resizable would be a plus
3.when I touch a fader on my control surface
It highlight the fader in studio one's mix and edit screen like logic has, marking these small inhancements
Will be a huge plus I believe for everyone
by Scoox on Fri Feb 09, 2018 8:02 pm
A chain for the Audio Part icon seems rather ridiculous, as does an arrow to indicate "frozen" event FX. What sort of drugs were they on?
Windows 10 64-bit Professional
Intel Core i7-6700K @ 4.00GHz, 32 GB RAM
Studio One 3.3.1.39379 Win x64
by Lawrence on Sat Feb 10, 2018 6:41 am
Makes sense to me, a chain indicating linked clips in an audio part. But that's how the world goes, everyone's a critic. :)
by Scoox on Sat Feb 10, 2018 2:01 pm
Yeah, it's true that every brain works differently :D
by cyndilaurie on Fri Dec 22, 2023 2:26 pm
I have found that the little gear icon appears after I have merged events. Once I see it, I cannot edit further until I bounce that track.
30 postsPage 2 of 2
1, 2
Users browsing this forum: No registered users and 110 guests
