If you want to send to a FX bus/channel post channel fader, try this.
Example: You may want to pan sends to a multi-mono compressor bus that reacts appropriately to panning from your working channel. * Bus the channel you're working with to a discreet stereo "Pan Bus" * Put the sends to your multi-mono buses on the pan bus Now you can send a post-pan, post-fader signal from your working channel the the pan bus, which manages your various other multi-mono bus sends. All of your pan automation is done on your working channel. This works great when you are working with multiple parallel buses. Party on! |
What is all this added complication?
Just use a send, by default its post fader, then just apply your pan settings to the send.
Toronto, Canada
Users browsing this forum: No registered users and 113 guests
