Is there anyway to set the output of a track to no output?
I don't see this option. I want to take my bass track, and create two bus channel sends. And then on those sends I want to add further processing and mix the two together. And then I want to the main bass track to be set to no output. The only other way I can think of doing this is choose a Bus Channel as the output and then dropping the volume on this bus channel track. |
You'll want to use the send insert on a track to route the audio to your desired bus. Set the send insert to pre-fader mode. You can now set the volume of the track to zero and it won't affect the volume of your sends that are set to pre-fader.
i7-7700k, Asus Z270-A, Windows 10 Pro, TI Chipset firewire controller, Firestudio Project w/ 6pin > 6pin cable ( Retired ), RME Babyface Pro, Studio One 3.5+, Softube Console 1, Faderport
Noise Implant - Auditory and Visual Stimulation |
garyhiebner wroteIs there anyway to set the output of a track to no output?You can create it yourself (https://answers.presonus.com/3663/fr-mi ... 3673#a3673). |
