Hey all,
I did a search for a macro threads, but couldn't find any. So, I'm starting one. Please add your macro, a short description and maybe a short GIF animation, that shows the macro in action. I'll start with two macros that I just created. Macro: Select Notes from Start to Cursor Description: this macro will select all MIDI notes from the beginning of the event until playhead cursor Some explanation about what is happening in the video: the loop markers are a very powerful tool. It's highly recommended to use them, if you plan to select notes and this cannot be done out of the box. What I do here is: - set the loop end to my actual playhead cursor - select the first note in the event (the Pos1 key or the shortcut "Navigation - Start") - then I locate the playhead to that position with "Locate selection" and set the loop start to that position - as final step, I select all notes that are located in the loop DONE!
